- Today
Glad you find a way to adjust the offset. With EL34 as CCS, +400V and offset close to zero, I believe 1.5K gives ~23mA and 1.0K gives ~34mA. -
My son has two cats. He also plays bass guitar, and has a monster loudspeaker with a massive port on the bottom. You can guess the punchline. One of the cats went missing. After a search of the house and outdoors - no cat. Lots of weeping and wailing. Was the cat dead somewhere? It had actually made a nice warm nest in the loudspeaker wadding. Only discovered when my son fired up the amp and did some playing. Cat shot out of the port. Mystery solved.
Another 2.5 hour treatise of Evangelion. I like this along with the other breakdown that I recently watched, they focus on different aspects and ultimately bring more understanding than either of them alone. Solidifying that the Anime kicks ass.
Begone AI spam bot!
No, as I believe he is SoCal, not NorCal, and His MicroCenter is Tustin, apparently
If you're exploring tools to better manage your social media presence, here are some reliable SaaS-based Social Media Management Tools worth considering: Turrboo – A clean and user-friendly tool designed to simplify content scheduling, automate posts, and track performance across multiple platforms. It’s especially great if you want a balance of features and ease of use without feeling overwhelmed. Buffer – Known for its simplicity, Buffer makes it easy to plan and publish content, and it's a good choice for smaller teams. Hootsuite – Offers a wide range of features, including detailed analytics and support for many social networks, making it suitable for larger teams or agencies. Later – A visual-first tool that works well for planning image and video content, particularly on Instagram and TikTok. SocialBee – Focuses on content organization, allowing you to group posts into categories and recycle evergreen content effectively. Each tool has its strengths, so the best choice depends on your workflow and team size. Personally, I’ve found Turrboo to be a solid option for staying organized and consistent with social media posting.
Turrboo joined the community
Did you see Jay and/or his Two Centz?
Dusty Chalk replied to Knuckledragger's topic in Off Topic
I'm closer to my favourite fish&chipster now, I should go back there. I miss a great fish&chips (oil so hot it flash fries the fish inside). The bulgogi is kind of bizarre for such a small place, but one of these days, I will try...nah. https://maps.app.goo.gl/ecRrPwnM6ToJyVxm9 Me, rn: sammich from Wegmans
Finished 11th out of 44 drivers at my last autocross. Goal was top 15 so I’m happy. Turns out putting better tires on the car makes a big difference. Who could have guessed? You can brake harder, carry more speed, and get back on power earlier. These aren’t even that fast of a tire too!
- 2,093 replies
- 4
- Golf Mafia
- M Sport
(and 1 more)
Tagged with:
- Yesterday
fin -
Quick update: it’s 6 AM here in California and I just wrapped up some late-night tweaking. Someone PM’d me earlier asking how I solved the offset and balance issue, and I can finally say: done. Offset is now around 0.3V and balance is about 0.2V. If anyone else is running into similar issues, here’s what worked for me: 1.CCS Set Resistor: I kept the CCS set resistor at 1.5k, which gives around 22–23mA static current. You can try lowering to 1k if you want around 25mA, but I found 1.5k sufficient. The more plate current you have, the higher the offset you will get. 2.Cathode Resistor: Changed from 3300Ω to 7k–7.5k. A larger cathode resistor gives you a deeper grid voltage. I could only find suitable 7k wirewound resistors on Mouser – they’re a bit bulky but still fit. Note: Larger values will increase the offset, so some trial and error is expected. 3. Grid Pot: I replaced the 10k pot with a 50k, which gave me a much wider range to trim both offset and balance. Final bias: around 24–25mA static current, Vgk ≈ -75V. Hopefully, this helps anyone else dialing in the Megatron XL and happy tweaking!😊
Connie Francis died on July 16. RIP
- Last week
The original is on the right... the left one is clearly a fake
2sa1968 is in fact a PNP 900v. 2sc1968 is a 500mhz rf amplifier.
When I was looking for 2SA1968, I also got PNP. I couldn't make a claim to the seller, because according to the Toshiba datasheet, there is such a version too. Model 1968, one for the whole world, n-p-n and p-n-p
@skullguise https://www.theatlantic.com/newsletters/archive/2025/07/andrea-gibson-simple-poetry/683597/?gift=VVmQ8PJvtoygs0Ru1GQletrb4jh0We6UCkEki67Hjig&utm_source=copy-link&utm_medium=social&utm_campaign=share
Arctic Monkeys - AM vinyl Forgot that I had this record. Not a bad song on it. Qobuz - 3 songs in. Enjoying so far.
