- Today
My condolences Steve. May she rest in peace. I'm glad you reached her. She passed away with peace of mind. Glad you could have a phone call. So sorry for your loss again...
- Yesterday
Zemir25 joined the community
Thanks for comment and link to ROHM document, @simmconn. Very much appreciated. That test had obviously no chance to be successful.
The TO-220 version of the 10M90S is readily available, so there's really no need to consider alternatives for now. Better to stick with what’s proven to work.
Not exactly the same part but being the same package they are more in common that they are different: https://fscdn.rohm.com/en/products/databook/applinote/ic/power/linear_regulator/to252_thermal_resistance_information_an-e.pdf In the final stage CCS, the 10M90S is dissipating 8W to 9W. The theta-JA needs to get down to single digit °C/W in order for the junction to stay comfortably within spec, not to mention that the output DC offset thermal drift has always been our enemy. TO-252 is not going to get you there. Also, even if the copper is well coupled with the aluminum angle, the tiny cross section would still give considerable thermal resistance. You are right in that it is just like the Ohm's law. With theta-JC being 3.1 already, there is not a lot of slack to play with. I think IXYS is being sloppy when it comes to thermal specs in the 10M90S datasheet, by specifying only one number for both packages. With some other parts having about 2x theta-JC in TO-252 than in TO-220, I doubt IXYS can do that much better.
- Last week
A few years late, but RIP Cris Hassold, professor at New College of Florida A Professor’s Final Gift to Her Students: Her Life Savings https://www.nytimes.com/2025/05/11/us/cris-hassold-professor-new-college-will.html?unlocked_article_code=1.Gk8.lsgk.I-V-0Fygppww&smid=nytcore-ios-share&referringSource=articleShare (Gift article)
I got as far as buying a griddle plate to go on my gas grill a little while ago, but not as far as actually taking it out of the box yet. Keep posting!
Since I don’t know how to calculate the thermal resistance between to-252 and heat sink out into free air I made this small test. I got a clear answer. I do know Ohm's law though.
D'oh!
* Cough *
Leogar43 joined the community
Sophie brought two babkas on her last visit: a nutella and a cinnamon and neither was the lesser. To quote another Seinfeld, they were real and they were spectacula!
Poor Elaine ...
Yep, if you had checked the theata-jc of those packages you wouldn’t have bothered with such “test”.
Haltian1625 joined the community
Live at the Leather Fly by Butthole Surfers (2025) https://album.link/zzrp2dwdc0rjm Example: Just relaxing with my latte...
Thanks for notifying. The more eyes the better and… No, I missed that damage. With L-bracket it looks like this. Clearence between +400V area and ground is 40 mil. So, I doubt that there has been an electric short. I suspect that, for a reason I don’t understand, the current rushed and 10m90 quickly over heated. At the same time the PSU gave up and all went silent. I guess it’s heat from 10m90s that caused the damage. But that is a 100% guess. Anyhow, I think I stick to to220 version of 10m90s and forget this mishap.
That 10M90S decided it was done with this world and took a leap of faith! Looks like it couldn’t handle the heat.☹️ Did you check this section? Looks like it was shortened by the solder.
Milled a small board to test IXCP10M90S(TO-252). Attached board to heat sink via L-bracket and sil pad for insulation purpose of course. When increasing current to 20 mA left side its 10m90s popped and left the board completely. Found it on floor. So, no more testing regarding surface mounted 10m90s. I’m very pleased with the new mini T2 board. Here with 300B via tube adapter with filament injection, 5VAC from transformer. Works great. Nice setup, don’t you think?
I forgot to take any pics, but today Al and I made smashburgers on the flattop, and they were phenomenal! I'm going to transport the griddle to work this Saturday (customer appreciation day), and I'll recreate the burgers for the crew. Customers will be eating hot dogs grilled by another employee on a Treager, but I thought the employees deserved a little better. The burger used was Costco's 4lb. Organic beef packages, and the 80% was just right. I'm going to follow suit with grilled mushrooms and grilled onions, exactly as Al did them, because his research was spot on! I'll have a choice of cheeses as we did today. Just absolutely delicious burgers, and an epic time with my besties! Followed up with a walk through Roy's Redwoods! Great day all around.
I'm never going to say "no" to new Arcade Fire, but this is kind of underhwleming by their high standards. A few good tracks but over way too soon (42 minutes).
I didn`t check the schematic. However, the input resistors(Signal input) shouldn`t be a probably if you go with 15k or 20k.
blessingx replied to Knuckledragger's topic in Off Topic
AROK, the future we were promised -
Samir5894 joined the community
l397 started following finally an electrostatic transportable
dingding123 replied to kevin gilmore's topic in Do It Yourself
17k smd resistors are quite hard to find. Would you recommend 20k or 15k ohm resistors?
