Posts
4,900 -
Joined
Last visited
Days Won
3
Content Type
Profiles
Forums
Events
Everything posted by Duggeh
I could have thrown in that one of the coax inputs doesn't work to see what might be done about that, but I only need one of them and have no plans to sell it so it seems moot. Listening now. Sounds better than ever. Clearly I used magical Russ Andrews solder
I'll get started on that SRM-T2 for you just as soon as I figure out how the battery goes into this multimeter
I used a solder sucker to remove the old joint then soldered it again. It isn't perfect. But it isn't a mess. Plugged it into the fiio e11, because a 20 kilogram DAC into a 20 gram amp is the done thing. Left channel is working fine and doesn't cut out if tapping or torque is deployed. So I venture to hope that it's fixed. DAC Saved! Thanks all!
Got the DAC down and open. Under magnification one of the joints on C334 does appear broken. This is the best picture I could manage. I'll resolder it and see if all is cured.
Thank you so much for the input so far guys. I don't think it is an issue with the relays (parts labelled OMRON) as a bit of work with forefinger and thumb confirms that tapping on those or anywhere else does nowt, while applying torque clockwise or anticlockwise to the large black capacitor (C334) brings back the music. This force might be moving the relay as well of course. I'm going to bring the DAC down to my desk and dig out my soldering iron. I hate moving the DAS-R1 because the mains lead is captive and getting it out means unbolting my drawers from the wall. Back soon. Kevin if you link me to the schematic I'll buy it and post it. Least I can do.
So for a little while now my Sony DAS-R1 has had a problem with the left channel cutting out. It used to get better by itself after a minute or so, then it needed longer. Now I have the lid unscrewed all the time and give it a wee tap. While this cures the symptom it doesn't cure the disease and the wee tap is now turning into a prod, before I know it, I'll be using a frame hammer. I'd like to fix this myself however I only just know which end of a soldering iron plugs into the mains and which end you use to burn your fingers touch against things to heat them up. I've looked under the board and I cannot see any obviously broken connections. I am fairly certain that the problem is in the connection to "the big black cube". Simply because that's where I'd tap for the most sure fire results. I throw myself upon the diagnostic wisdom of the great and the good here. Photos resized to 1024x768. I'm also uploading the fullsize ones. I can photograph anything you like in detail if it helps.
Hippitty Burpdai Smegster!
Hippitty Haff Sennchuree!
Hippitty Burpdai Fitz!
Glad that the new stylus is working
With the not huge jump in price given whats new inside this thing one has to wonder just how big the profit margin was on the G1 and G2 iPads. Somewhere between large and vast I wager.
More Hipster Than Though, the obscurity pissing contest.
Duggeh replied to Knuckledragger's topic in Music
There has to be an error somewhere when my own Ejay songs from high school are less obscure than R. Cajun or Hank Shizzoe. -
Hippitty (Belated) Burpdai!
Hippitty Burpdai!
Can one buy balanced armature drivers without buying an IEM? One of those would do.
http://www.telegraph.co.uk/science/space/9105709/Economists-calculate-the-cost-of-building-a-Death-Star.html
Hippitty Burpdai!!!
Oh now that is a sweet wee distillation rig.
Does this guy seem a little familiar to anyone? http://www.break.com/index/the-periodic-table-table-2303849 -edit- Couldn't get the video to embed.
Hippitty Burpdai Ed!
Hippitty Burpdai Dood!
Hippitty Burpdai Dan! Have a totally (g)rawking day!
Watching 8 seasons of television in one night requires a Flux Capacitor and a car with gull wing doors. Elsewise, it's relate central.
