Posts
13,630 -
Joined
Last visited
Days Won
34
Content Type
Profiles
Forums
Events
What about blutarsky? When is this thing
Just for knowledge acquisition - water based stains go on before an oil finish but oil based stains can go on anytime (including between coats?) I need to grain fill a bit so my worry about adding a stain on first is that I blow through it as I am trying to fill in the pores with the oil finish. I would prefer something I can apply anytime hence the question about a tint in the oil finish.
Thats correct. First photo is raw after the repair and second is one coat of the linseed finish. Think I need to go darker quicker without applying more finish coats..
Hi all! I am repairing a piece of walnut that broke off and am in need of a stain to darken and color match. I am not sure what the best approach might be - tinting a linseed based oil finish or applying a water-based stain and then finishing with the above oil based finish. Any suggestions?
nice router table!
I dunno, one time I saw you put the wood in the wrong direction. Just saying.
Uh no. I see now. Sadly none at Woodcraft.
I went team Head-Fi and found the cheapest thing that I am here to tell you is amazing. It seems to be good enough for my little project. I wish the holes lined up on the pad saver so dust extraction would be better though. Making a trailer storage solution for a sailboat using marine ply and epoxy.
There isn’t a multi grit option in smaller quantities - ya gotta pay $70 a box.
Went to an acquaintance who has like all the green tools and compared the ETS EC 150 to the regular one. Actually preferred the non EC and just picked it up in 3mm. Super annoying there isn’t a mesh/net disk assortment. Specifically having an issue with west system epoxy clogging up the regular paper backed disks and looking to try something new out.
Enjoy some music, make me money - shameless affiliate plug
luvdunhill replied to skullguise's topic in Off Topic
The obligatory MOTMOTMOTMOT -
Nice! Definitely a step up!
Very cool. Needs more scrolling though.
Is there a way to define an area and have a pattern design filled in that area, or are these designs just made for these specific dimensions?
luvdunhill replied to kevin gilmore's topic in Do It Yourself
Seems reasonable. Team 5-pin approves. -
Wow that’s super cool!
I see. So the steel pieces are the wall. If I secure it to the concrete on the right (yes Al is correct with his marking) then it no longer will be straight. If I don’t secure it, it will be nice and straight, but there will be a gap between the steel wall and the concrete on the right. I would need to fill it with some sort of coating (Sika makes a self leveling material and there is some you heat up as well..)
I like things straight, what can I say. So looking for advice. Do I attach my steel wall to the concrete and live with a wavy line, or leave a gap and fill it in later with concrete. I plan on using metal stakes and concrete on the back side of the not-so-great-wall so that would make it straight.. I already want to raise the wall a bit so this is just a dry fit to mark the holes for the to be concreted posts
Axe? Chainsaw? We need more details!
Cool. I got my son an Audio-Technica Sound Burger. It was a hit.
It fit! Thanks! I opted to not test it out .. but ready when I feel up to it. I submitted the warrantee form as well. I am not in a huge hurry but come Jan if I haven’t heard back, I think I will just order the EZS in a smaller capacity and move it into the larger bar.. that seems easy enough.
I don’t think I know what that is. I suppose I can buy a smaller clamp and just pull the mechanism off of it. I need something that be both a spreader and a clamper. These are quite old - we used them on the corner horns. I filled the warrantee with Bessey just now, we will see what they do.
I recently had an occasion to use my clamp as a spreader. Worked great but I am now not able to get the bar back in the head. I have tried moving around these oblong disks inside with a knife but they won’t budge. Has anyone fixed their clamp or should I just see how the Bessey warrantee works..
So I am trying to figure out if this wheel: will fit on this angle grinder: https://www.metabo-hpt.com/us/main-navigation/item/g12sr4-6-2-amp-4-1-2-angle-grinder-w-5-abrasive-wheels-Metabo-HPT But I don’t have the angle grinder with me, it’s 4.5” vs the 4” diamond blade and I am not sure if the removable arbors can be put back on.. most 4-1/2” seem to be 7/8” anyways so I am probably fine.. any ideas? I have about a foot of 1-2” thick Texas limestone (Lauder) need to trim off on my footpath and don’t want to buy another blade this one might be too small but I am going to give it a shot and see if I can just chisel the rest off..
