Horio Posted April 5, 2012 Report Share Posted April 5, 2012 And i have at least 2 more projects planned for this year Pretty insane. Oh dear... Any hints? Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted April 5, 2012 Report Share Posted April 5, 2012 fingers crossed for a modernized T2 with SS frontend. Quote Link to comment Share on other sites More sharing options...
n3rdling Posted April 5, 2012 Report Share Posted April 5, 2012 SS?! Are you crazy?! It won't sound 3D!! Microdetail!!! Minidynamics!!!! Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted April 5, 2012 Report Share Posted April 5, 2012 It will still have output tubes. Quote Link to comment Share on other sites More sharing options...
spritzer Posted April 5, 2012 Author Report Share Posted April 5, 2012 I don't even want to think about all the pending projects and the cost of building them... Quote Link to comment Share on other sites More sharing options...
FrankCooter Posted April 9, 2012 Report Share Posted April 9, 2012 Dug out the Egmont variant I made a while back and reinstalled the original 6BL7 outputs (I was using triode connected 7591's) and changed the the cathode bias to fixed bias. Preferred the 7591's by a small amount (an NOS quad will run $300.00 compared to $30.00 for a pair of 6BL7). Changing the bias scheme, although I can't measure the results, resulted in a signifigant subjective improvement. The amp seems punchier, more defined, and tighter in the bottom than with cathode bias. Definitely worth the small additional complexity. I used a battery stack as a neg. supply to get things started, but as a permanent solution (assuming you are building your own supply) I'll simply use a tapped voltage doubler off the neg. rail ( basically a mirrored image of the headphone bias supply). Quote Link to comment Share on other sites More sharing options...
spritzer Posted April 9, 2012 Author Report Share Posted April 9, 2012 Fixed bias is indeed a much better way to do this. For the extra negative supply I'd just make small, fully floating, regulated supply but pretty much anything works. Batteries are a fun way to do it especially with a large sign saying not to touch... One of my friends got a bit too close to the ES-1 when I was testing it's revised output stage but one mention of the batteries floating at -460V was enough for him to back off. While we are on the subject, I'm making slow but steady progress on my B-10 (improved A-10): Trying to keep this as small as is possible so 1U for the amp and same size 2U chassis for the PSU. Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted April 9, 2012 Report Share Posted April 9, 2012 self bias was always a sleezy (and by that i mean cheap) way to avoid the extra power supply, decrease the gain of the output stage, and increase distortion... Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted April 9, 2012 Report Share Posted April 9, 2012 +1 I almost immediately discarded this option on the SIT circuit I'm playing with. Quote Link to comment Share on other sites More sharing options...
Victor Chew Posted April 10, 2012 Report Share Posted April 10, 2012 And i have at least 2 more projects planned for this year Pretty insane. Electrostatic and dynamicin one build? Quote Link to comment Share on other sites More sharing options...
wink Posted April 10, 2012 Report Share Posted April 10, 2012 Digital and analogue in the other? Quote Link to comment Share on other sites More sharing options...
spritzer Posted April 28, 2012 Author Report Share Posted April 28, 2012 (edited) Time for an update on the B-10 as it is now called. I decided it was just best to stick with Rays fubar amp design but improve on it where possible so the volume control was moved to the front of the circuitry (not in the middle as on the A-10), grounded DC heaters used for the input tubes and AC heaters used for the output tubes (hungry at 4A). Now using a SRPP setup in a single tube is rather stupid since it means there is too much voltage on the cathodes for the cathode/heater gap. Best way to mitigate this is to use a center tapped heater winding and float it on +300V so this only becomes an issue with the amp swinging 500V or more. Other than that the amp is pretty much stock and here are a couple of pics: The psu will be in a same size chassis but 2U in height. I designed a new PCB for it loosely based on the old GES supply which should arrive soon. Edited April 28, 2012 by spritzer Quote Link to comment Share on other sites More sharing options...
Victor Chew Posted April 29, 2012 Report Share Posted April 29, 2012 Very Nice Birgir. What volume pot is it that you are using. Tiny little thing. Any expectation of te sound? Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted April 29, 2012 Report Share Posted April 29, 2012 That is the alpha pot. Very nice actually and of reasonable size. Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted April 29, 2012 Report Share Posted April 29, 2012 Birgir, I've made a bunch of adapter pcbs for the alpha pot and ended up with some extras. Do you want them? Quote Link to comment Share on other sites More sharing options...
keithpgdrb Posted April 29, 2012 Report Share Posted April 29, 2012 I'm very interested in the implementation of improving the a10. Very cool. Although its not the poor mans amp, which sounds über fun! Quote Link to comment Share on other sites More sharing options...
spritzer Posted April 29, 2012 Author Report Share Posted April 29, 2012 Any expectation of te sound? I cobbled together a version of this circuit when the A-10 first came out so I have a good idea how this one will sound. Thick with distortion and no output power what so ever. There are some tricks here though to try and make the SRPP circuit behave as it should (it only really works into a fixed impedance) so there should be a marginal improvement. For me the enjoyment is building this stuff even if it will sound sucky and with these tube amps it's a lot of fun to dig through my castoff bins to find the parts I need. All the terminal strips in this amp are from the ES-1, the plate resistors for the ECC83's are the brilliant TKD CM2's pulled from a SRM-T1 and the coupling caps are from my first ES-1 repair attempts. I never throw anything away... Birgir, I've made a bunch of adapter pcbs for the alpha pot and ended up with some extras. Do you want them? Sure, I still have a pile of the Alpha pots left. Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted April 29, 2012 Report Share Posted April 29, 2012 I'll take a couple of those adapter boards, i have a bunch of those pots... Quote Link to comment Share on other sites More sharing options...
Nebby Posted April 29, 2012 Report Share Posted April 29, 2012 I would like some of those pcb's as well if there are any left Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted April 29, 2012 Report Share Posted April 29, 2012 The pcbs look like this: I've got 5 of these things left, how many would you guys like to have? Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted April 29, 2012 Report Share Posted April 29, 2012 1 or two for me please Quote Link to comment Share on other sites More sharing options...
n_maher Posted May 2, 2012 Report Share Posted May 2, 2012 One for me please. Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted May 2, 2012 Report Share Posted May 2, 2012 I'm all out. Sorry. Quote Link to comment Share on other sites More sharing options...
Beefy Posted May 2, 2012 Report Share Posted May 2, 2012 I'm all out. Sorry. Ban, surely...... Quote Link to comment Share on other sites More sharing options...
ujamerstand Posted May 2, 2012 Report Share Posted May 2, 2012 Quote Link to comment Share on other sites More sharing options...
