Group Buy for KG's Boards (2nd)
Lil Knight
Had heard of oil before (and WD-40 in particular) for packing tape glue, but was worried about thoroughly cleaning the through-holes after. So no problems on that front?
Should not be a problem when you soak the entire PCB in solvent.  I use WD-40 to remove all sorts of glue-ish stuff, like stickers, residue, and decals.  It makes very short work of that stuff.  You can even use it to remove registration stickers on your license plate.  Glue residue doesn't like oil.
Here's a video I found on youtube just now.
The acetone should work too.
