luvdunhill Posted December 10, 2014 Report Share Posted December 10, 2014 edit: +n't Quote Link to comment Share on other sites More sharing options...
dreamwhisper Posted December 10, 2014 Author Report Share Posted December 10, 2014 (edited) Oh I ended up buying a GS-1 not a Beta 22. Sorry for the confusion. Is it the power output of the Beta that's the dangerous part? Did I hurt my GS-1? I've done it once or twice. Eagerly awaiting your response. :/ Edited December 10, 2014 by dreamwhisper Quote Link to comment Share on other sites More sharing options...
RudeWolf Posted December 10, 2014 Report Share Posted December 10, 2014 It's the MOSFET output stage. Quote Link to comment Share on other sites More sharing options...
dreamwhisper Posted December 10, 2014 Author Report Share Posted December 10, 2014 (edited) What's in these modules? Any specifics? This is an all-new module designed in-house. It will be the first non-Gilmore amplification circuitry I have offered in a home amp. It is a 100% discrete design, real Class A circuit. The output consists of a pair of Hitachi MOSFETs designed for audio -- good for a substantial couple of watts in this circuit. Edited December 10, 2014 by dreamwhisper Quote Link to comment Share on other sites More sharing options...
spritzer Posted December 10, 2014 Report Share Posted December 10, 2014 Nothing to do with mosfets in general. It's due to the TRS shorting the outputstage to ground Quote Link to comment Share on other sites More sharing options...
RudeWolf Posted December 10, 2014 Report Share Posted December 10, 2014 (edited) Some output stages are more fickle with this than others. That being said - it's a good idea to turn volume down when swapping headphones or just putting an XLR pigtail on the amp. Edited December 10, 2014 by RudeWolf Quote Link to comment Share on other sites More sharing options...
chiguy Posted December 10, 2014 Report Share Posted December 10, 2014 To add to all of this, there are two resistors on each channel board that can be upped to provide some additional protection against the TRS shorting. I don't remember the details but they are over at the AMB forums. Quote Link to comment Share on other sites More sharing options...
Remolon Posted December 10, 2014 Report Share Posted December 10, 2014 What I do is to put a mute circuit at the output. There is a switch that direct the signal to the headphones or to ground through a resistor (I use 300R). Quote Link to comment Share on other sites More sharing options...
dreamwhisper Posted December 10, 2014 Author Report Share Posted December 10, 2014 Do you have a link where you can buy something like this? Quote Link to comment Share on other sites More sharing options...
HeadphoneAddict Posted December 11, 2014 Report Share Posted December 11, 2014 Depending on when this beta was built and how the output is configured I'd first start by saying that you should never hot swap or plug in headphones on a beta²². That's a good way to release the magic smoke and render the amp useless. Unless you're talking about an amp configured with a connector other than the usual 1/4" TRS jack. That jack causes a momentary short on the output when plugging/unplugging headphones that has been known to cause major issues. That said, there should really be an issue powering two headphones at once off of the beta, just that if the sensitivities/load are significantly different it may be difficult or impossible to find a happy listening volume. Someone killed Asr's B22 at a headphone meet by hot swapping phones with music playing. It sucked. Quote Link to comment Share on other sites More sharing options...
n_maher Posted December 11, 2014 Report Share Posted December 11, 2014 edit: +n't Correct, as usual. Quote Link to comment Share on other sites More sharing options...
The Monkey Posted December 20, 2014 Report Share Posted December 20, 2014 I still love my Nugget Audio B22. 2 Quote Link to comment Share on other sites More sharing options...
K3cT Posted May 1, 2015 Report Share Posted May 1, 2015 I find increasing the quiescent current of the output device from amb's recommendation of 120 - 160 to around 180mA helps warming up the sound. Quote Link to comment Share on other sites More sharing options...
swt61 Posted May 1, 2015 Report Share Posted May 1, 2015 I found that plugging in a TRS jack with the unit at a good volume warms everything up. 2 Quote Link to comment Share on other sites More sharing options...
