and now for something definitely different part 4
kevin gilmore
so this has been kicking around for a while, decided to publish.
take my ubaltobal converter, cut it in half, and then take the top
piece, replace the input transistor with a tube...
high impedance input...
DC coupled, no negative feedback, less than .01% thd, 10db gain...
just add a high power bipolar output buffer, and cheap tube hybrid
with lots of plankton.
work in progress
http://gilmore.chem.northwestern.edu/tubehybrid.pdf
100 volt power supply real simple with TI TL783 high voltage regulator
+/-30 supplies with lm317/lm337 with boosters
cheap!
  • Like 1
How about a differential (EDIT and high gain) version as an input to a electrostatic output circuit? That is, a Megatron without the coupling capacitors.
Coupling caps are evil, I use teflon and that costs a fortune for the megatron.
Edited by Earspeakers
How about the SRX revisited? This also might be interesting: http://gilmore.chem.northwestern.edu/electra4.pdfThe circuit is easy enough to p2p and replace resistors with current sources.
this circuit is ground referenced, so not suitable for megatron style stuff.
Unfortunately, the only thing that works there is the T2 circuit, or something
like it due to having to drive the output tube at -500V
was not aware of the other Fairchild parts, definitely in this case better than
the higher voltage parts. Really only need 200V parts
since grindingthud seems to be faster at building and testing my stuff than I am...
http://gilmore.chem.northwestern.edu/th.jpg
http://gilmore.chem.northwestern.edu/thps.jpg
http://gilmore.chem.northwestern.edu/boards/th.zip
http://gilmore.chem.northwestern.edu/boards/thps.zip
the big high voltage cap is actually 470uf 160v and
the little cap is actually 33uf 160v
they are right on the boards, wrong on the pictures
schematic
http://gilmore.chem.northwestern.edu/th.pdf
  • 3 months later...
congo5 building and troubleshooting now.
+ and -15 flipped and -5 cap on amp board flipped
all fixed.
congo5 says its working now. :D
one other thing, because of the tube, a warmup circuit
or better, and output protector is required
th2.zip has the output protector on the boards
