transconductance amp
kevin gilmore
Interesting development.
I was looking into the Bakoon headphone amp several months ago out of curiosity and again this week to power Fostex TH900's which are easy to drive (i.e. overkill) and HD650's, both currently powered by a Woo WA7.  The difference though, if I've read the prior posts correctly, is that I was not looking into the Korean version that's battery powered.  The Japanese HDA-5210 MK3 SATRI-IC-EX is the one I found much more interesting and would be more practical for my needs.
Are you putting the Japanese 5210 Bakoon in the same boat with the Korean HPA-21 Bakoon?
Thanks.
HS
Have the transconductance amp up and running at 25V currently. Brilliant sound, really like it! In addition to being good for planars, also does wonders for my older AKGs.
While waiting for a few more resistors to arrive so I can set the GRLV at 30V (simply didn't have any useful combo at hand), is it possible to estimate the current draw at 30V? Thinking of running a balanced version off a single GRLV.
I hope more of these get built and we get to read impressions/comparisons.  It's looks like a nifty amp.
The only commercially available amp that's piqued my interest for use with my TH900's is the Japanese made Bakoon (not the Korean made battery powered one).  There are a few versions / options available and this is the plain vanilla one.
http://www.amazon.com/Bakoon-Headphone-amplifier-HDA-5210MK3-SATRI-IC-EX/dp/B00MWMJ5HI/ref=sr_1_4?ie=UTF8&qid=1454339536&sr=8-4&keywords=bakoon+amplifier
HS
On 1/26/2016 at 10:40 AM, congo5 said:
with 30v rails I measured
2.27v across the 50R  .054ma
2.34v across the 562R .004ma
so standing current is very low, just add what current you want going to your phones.
Silly question, but what do you mean by "want going to your phones"?
How would you calculate that for, lets say 35 ohm HE1000? Applying ohm's law, that's almost 2A with 30V rails (60v) and that can't be right...
Edited by FallenAngel
Quote
This is about the current flow through the headphones when there is no input.
If you were getting rail voltages, the amp would be seriously broken.
You calculate the curent flow through the impedance/resistor ( the headphones) by the voltage across the impedance/resistance divided by the impedance/resistance.   i.e. I=E/R
2.27/50=0.0454A = 45.4mA.
2.34/562=0.0042A = 4.2mA
If you had 30V into 35 Ohms = 30/35=0.857A = 857mA
More realistically 2.27/35 = 0.0649A = 64.9mA.
Edited by wink
more info
  • Like 1
Use heatsinks like in Kevin's picture above, I used these
532-529802B25G
for the power supply mount the two pass transistors to the case or find a sink, examples are in pictures on this site,
As for current for phones, with my phones (Sensitivity : 96 dB/mW) 50R ortho's I measure 2vrms when they are Loud..   2v / 50R = .04A
so allowing for peaks  I might need  300ma?
  • Like 1
