SRX-Plus Build Thread
Blueman2
I just did the gerber files for my PS.  Also have a schematic but this is all in KiCAD, so not sure how to proceed from here.  The PS supply is the same as the schematic in the SRX revised thread except for the addition of an 0.1 uf/1000v cap on the input side between B+ and B-.  The PS does not include the bias supply but I used KG's design anyway and I believe that is available as a separate board.
Edited by JimL
Well, I can install KiCAD and export something suitable for ordering PCBs and then pass on to mwl168 if that is the question?, or is there something else I can do to help? Would really like to try your PSU :), so just let me know how I can support...
So, I thought I had finished the PCB design, but there were a couple missing holes, and then the more I tried to correct things the worse it got, so I don't have working Gerber files at present.  GRRRR!  I'm traveling today, so will try again tonight.  If worst comes to worst, may have to start from the beginning.  Part of the problem is that I tried to incorporate a ground plane into the PCB, then have the mounting holes connect to the ground plane.
Edited by JimL
Jim, is this for the Amp or the PSU?
So just a quick update.  I am currently stuck in trying to design a PCB for the PSU.  I've got it mostly done but there is one connection that I haven't been able to make - I mean literally KiCAD won't let me connect two parts.  I've tried deleting the connection in the schematic and reconnecting it, and reloading it in the PCB design module, I've tried manually drawing it in the PCB design module - it just won't let me do it.  I'm going to try starting from scratch again this weekend.
Pars, thanks for the offer, but if you haven't used KiCAD you're probably going to have at least as much trouble as I had.
Dr. Gilmore, Thanks you for the very generous offer.  Here are jpgs of the schematic, bottom copper with and without the component layout, and top copper.  I believe there is only one missing connection.  My layout uses an aluminum bracket because the MOSFETs should be able to withstand 35 watts or so if the amp boards go south and the entire current has to run through the shunt.  Most of the connections are on the bottom copper, with two vias to the top copper, and a couple ground connections on the top copper which could be replaced with a ground plane on top.  This is my first attempt at laying out a PCB so if you find a better arrangement feel free to change it.
The 10M90S and DN2540 are available on Mouser, and I just checked that the 19NM50N MOSFETs are also available at Mouser, as is the SPX431.  I chose those MOSFETs for their low on resistance, which is better than most, but other 500 volt rated MOSFETs can be used.
So the input electrolytic caps are 35 mm diameter.
The 0.1 uf/1000v caps (C3, C4 C9) are 27x11mm rectangular, 22.5 lead spacing
The 22 uf/450v caps (C7,C8) are D-Link 36.5x31.5 rectangular, 27.5mm lead spacing
C6 is 2.2 uf 50v
R12 and R18-22 are at least 1 watt, 500 volt, other resistors are 1/2 watt.
  • Like 1
Yes, the board layout doesn't show it because KiCAD doesn't have a footprint that large.  But that's the specs of the TDK D-Link on the Mouser website.  As Donald Trump would say, they're UUGE!  On my point to point build I used Solen polypro caps which measure 2.3" long by 1.5" diameter, and they're UUGER!. That's the reason I left space on the board layout instead of bringing the surrounding resistors close to the cap footprint.  I see you added the bias board.
BTW, it occurred to me that with an amp using outboard heatsinks, you could use this as a mono PS, one for each channel, and between the amp and the PS the current draw should be absolutely stable, although it's pretty close in any case.
Also, the reason I didn't include the rectifiers on the board was in case someone wanted to use a choke input, in which case the rectifiers would have to come before the choke, so the transformer, rectifiers and chokes would be wired point to point and the raw B+/B- and transformer CT to ground would then go to the board.
Um, don't see the SPX431, protective zener and caps that are supposed to control the voltage.  Also the output block should be 6 pins rather than 7.
Edited by JimL
Ah ha!  The C- supply is just a dropping resistor.  I don't think it needs anything else since it goes to the input tail current source which should isolate it from noise and hum.
Guess that board is too big for two mono supplies. My original board without the input rectifier and bias supply was about 6.6x 3.6 IIRC, but I cut it pretty close.  As long as we're at it, do you want to have provision for normal bias headphones as well?
BTW, I like your layout of the SPX431 much better than mine, cleaner pathway. :)  Told you I was new at this.
Also, if anyone wants to use a off board rectifier and choke input they can just jumper two of the input rectifiers and leave the other two unpopulated.
Edited by JimL
Yes, bypass caps should be put as close to the amp power entry as possible, but the main reason I put the caps on the output is based on a comment by John Broskie, "My experience with shunt regulators has been that without some capacitance on the output, expect some oscillation."
Also, to go back to my previous comment about the SPX431 layout, I realized after some more thought that there was another missing connection between the output of Q4 and R12, which KG noticed and I didn't.
Edited by JimL
