Sherwood Posted August 31, 2016 Report Share Posted August 31, 2016 (edited) My latest signal path has started with Roon, which is a piece of software I really enjoy. It sounded excellent, but recently I found that I could fuck with it a little more and spend time twiddling knobs, and I'm powerless to resist that. Most notably, Roon makes it simple to delegate all the actual "file playing" duties to another program, HQPlayer. Roon and HQPlayer represent significantly different approaches to music playback and management. Roon focuses on metadata, art, liner notes, reviews: basically the kind of edifying stuff you read and think about while listening to music. HQPlayer focuses on filters, and by Jesus are there ever a lot of them. And not just filters! You also get to play with modulators, sample rates, etc. There are a lot of parameters you can set regarding how you would like your D/A math performed. Many people who use HQPlayer with a DSD DAC prefer to upsample everything -- DSD and PCM -- to the highest resolution DSD stream their DAC can process. This is exactly what I've been doing, and it really sounds fantastic. Is anyone else using an external upsampler, either as part of software or a hardware piece like the dCS, and getting good results? I'd love to know why it is that this sounds so good. Edited September 3, 2016 by Sherwood EDIT: added links Quote Link to comment Share on other sites More sharing options...
jvlgato Posted August 31, 2016 Report Share Posted August 31, 2016 HQPlayer? Hmmm ... I have some reading to do ... Quote Link to comment Share on other sites More sharing options...
Sherwood Posted September 2, 2016 Author Report Share Posted September 2, 2016 Well, if you get too deep down the rabbit hole, I can share my settings: 2 Quote Link to comment Share on other sites More sharing options...
skullguise Posted September 3, 2016 Report Share Posted September 3, 2016 HQPlayer is likely in my future, been reading about it a bit, thanks for the post Tyler. Quote Link to comment Share on other sites More sharing options...
Torpedo Posted September 3, 2016 Report Share Posted September 3, 2016 It looks interesting. Does it support .iso SACD rips? Quote Link to comment Share on other sites More sharing options...
Sherwood Posted September 3, 2016 Author Report Share Posted September 3, 2016 2 hours ago, Torpedo said: It looks interesting. Does it support .iso SACD rips? That's a good question, Antonio. I've already converted all my .iso to dsf, which both Roon and HQPlayer play wonderfully. I'll try to grab another .iso and see how they handle everything. Quote Link to comment Share on other sites More sharing options...
Torpedo Posted September 3, 2016 Report Share Posted September 3, 2016 Thanks, Tyler. If it doesn't play them, what procedure would you recommend to extract the dsf files from the .iso on a Mac? I've tried some command line thing I found, but it ended up being too tedious for the disk space savings. Quote Link to comment Share on other sites More sharing options...
rdreyer Posted September 3, 2016 Report Share Posted September 3, 2016 2 hours ago, Torpedo said: Thanks, Tyler. If it doesn't play them, what procedure would you recommend to extract the dsf files from the .iso on a Mac? I've tried some command line thing I found, but it ended up being too tedious for the disk space savings. I use the Sonore Java app: http://dsd.sonore.us/iso2dsd_OSX_v6.zip Note that I convert to dff, not dsf, since I find that dsf is never truly gapless in my system (Audirvana to Ayre DAC). Whenever I play a gapless album (DSOTM, classical recording), I get a very slight click between dsf tracks (and I've tried about 4 or 5 different dsf conversion methods), that is only audible over headphones. I have no such issues with dff. I use Yate to tag those dff files, and Audirvana can read those tags. Quote Link to comment Share on other sites More sharing options...
Torpedo Posted September 3, 2016 Report Share Posted September 3, 2016 Hehehe I'd firstly need to comprehend the difference between dsf and dff files which could be relevant to my interests. I'm using Audirvana (the older version without the fancy iTunes-like GUI) to play the .iso files. Thanks for your input, rdreyer Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted September 3, 2016 Report Share Posted September 3, 2016 Try TRAX, it seems to work better than Sonore. Quote Link to comment Share on other sites More sharing options...
rdreyer Posted September 3, 2016 Report Share Posted September 3, 2016 18 minutes ago, luvdunhill said: Try TRAX, it seems to work better than Sonore. Trax (the free trial version) is one of the methods I tried for dsf extraction, but it still gave me a slight click/pop between tracks on gapless albums. Quote Link to comment Share on other sites More sharing options...
Torpedo Posted September 3, 2016 Report Share Posted September 3, 2016 I'm going to try to extract the DiFF files from an iso. Should i use the Philips DSDIFF output or the DSDIFF Edit master? Yet another one, do iso files always contain DSD stream or sometimes it could be DST? Were this the case, any way to know? Is it necessary to convert the DST into DSD before creating the DFF or DSF files? I'm too old for this shit, I think that's why I decided to stay with iso files hahaha. Quote Link to comment Share on other sites More sharing options...
rdreyer Posted September 4, 2016 Report Share Posted September 4, 2016 6 hours ago, Torpedo said: I'm going to try to extract the DiFF files from an iso. Should i use the Philips DSDIFF output or the DSDIFF Edit master? Yet another one, do iso files always contain DSD stream or sometimes it could be DST? Were this the case, any way to know? Is it necessary to convert the DST into DSD before creating the DFF or DSF files? I'm too old for this shit, I think that's why I decided to stay with iso files hahaha. You want to use Philips DSDIFF instead of DSDIFF Edit Master, as this will split the album into one file per track, instead of a single track. AFAIK, some SACD ISO files do have DST, so you also want to enable the "Convert DST to DSD" option. DST is a compressed format, which cannot be tagged. You do not need an extra step for this, just convert straight from ISO to DFF with that option enabled. 2 Quote Link to comment Share on other sites More sharing options...
Torpedo Posted September 4, 2016 Report Share Posted September 4, 2016 Thank you very much, rdrayer I'm going to try it right away. It worked like a charm and seemed to include the tags without my intervention. This DSD thing sounds awesome, probably the mastering, yet.. 1 Quote Link to comment Share on other sites More sharing options...
MLA Posted September 4, 2016 Report Share Posted September 4, 2016 (edited) Went down the HQplayer rabbit hole a while this weekend. Brilliant piece of software! Many thanks to @Sherwood for posting this! Soon realised that Jussi (the coding guy behind HQplayer) implemented a closed-form filter a few months ago, the merits of which Schiit has devoted a long section of their Yggy FAQ to. Pretty much the secret sauce in the Yggy. So for anyone who would like to try that sauce without buying the Yggy, here's the free trial option. Of course, a DAC is so much more than the filter and algorithms may differ, etc but it makes for a very interesting listen. Found a nice explanation on the merits of closed form vs apodising filters at http://www.computeraudiophile.com/f11-software/hq-player-20293/index147.html#post475586 Edited September 4, 2016 by MLA 2 Quote Link to comment Share on other sites More sharing options...
Sherwood Posted September 5, 2016 Author Report Share Posted September 5, 2016 22 hours ago, MLA said: Went down the HQplayer rabbit hole a while this weekend. Brilliant piece of software! Many thanks to @Sherwood for posting this! Soon realised that Jussi (the coding guy behind HQplayer) implemented a closed-form filter a few months ago, the merits of which Schiit has devoted a long section of their Yggy FAQ to. Pretty much the secret sauce in the Yggy. So for anyone who would like to try that sauce without buying the Yggy, here's the free trial option. Of course, a DAC is so much more than the filter and algorithms may differ, etc but it makes for a very interesting listen. Found a nice explanation on the merits of closed form vs apodising filters at http://www.computeraudiophile.com/f11-software/hq-player-20293/index147.html#post475586 I'm really glad you're enjoying it, @MLA! I've been bounding back and forth between the closed-form filter and the polysinc short filter shown in my settings above. The closed form seems to have better imaging and spatial cues, while I like the transient response of the poly sinc filter. All of them I've tried are good, but those are my usual go-to. 1 Quote Link to comment Share on other sites More sharing options...
MLA Posted September 5, 2016 Report Share Posted September 5, 2016 (edited) Well, it's only been a few hours of listening, but I have come to pretty much the same conclusions. The closed from does something with the room presence, the room gets smaller but the sense of space is stronger. The poly-sincs have better bite, but a little less "in-the-room" feeling. I guess it comes down to what music it is and where it was recorded. For me, current conclusion is closed form for jazz, chamber music and live concerts from small to medium size venues. Poly sinc for stuff with lots of electronica in it. It's wonderful to be able to choose I should add that for me, it takes the high end gear to make the distinctions. Carbon/007 yes, HD800/Sysu Dynalo yes, HD650/M3 no... Edited September 6, 2016 by MLA Quote Link to comment Share on other sites More sharing options...
Sherwood Posted September 5, 2016 Author Report Share Posted September 5, 2016 2 hours ago, MLA said: HD800/Sysu Dynalo yes Yes, indeed. 2 Quote Link to comment Share on other sites More sharing options...
swt61 Posted September 5, 2016 Report Share Posted September 5, 2016 Just listen to the beautiful, beautiful music. Quote Link to comment Share on other sites More sharing options...
Sherwood Posted September 6, 2016 Author Report Share Posted September 6, 2016 20 hours ago, swt61 said: Just listen to the beautiful, beautiful music. You take that subjectivist nonsense elsewhere, Tice. We have maths to fuck with, here. 2 Quote Link to comment Share on other sites More sharing options...
swt61 Posted September 6, 2016 Report Share Posted September 6, 2016 I was channeling Jamato for a sec., don't know how that happened? 1 Quote Link to comment Share on other sites More sharing options...
Sherwood Posted September 6, 2016 Author Report Share Posted September 6, 2016 I still love you. Let's never fight again. 2 Quote Link to comment Share on other sites More sharing options...
Hopstretch Posted September 6, 2016 Report Share Posted September 6, 2016 Now kiss. 3 Quote Link to comment Share on other sites More sharing options...
CarlSeibert Posted September 7, 2016 Report Share Posted September 7, 2016 But who'll kiss Jamato? 1 Quote Link to comment Share on other sites More sharing options...
Dusty Chalk Posted September 7, 2016 Report Share Posted September 7, 2016 That's one of them rhetorical questions, innit? 2 Quote Link to comment Share on other sites More sharing options...
