The State of DACSES
Can the Lumin Shills tell me if it has HP out?  I think you guys are all using HP amps, correct?
Also, have the shills connected it to a speaker system?  Good enough volume control to act as a preamp for a basic system I presume?
  • Like 1
  • Haha 1
Mike has his connected to speakers but uses a preamp I believe. I have the T2 connected to the GSX-mini (ridiculously good). No headphone out on the Lumin and both Mike and I use it with Roon. If you buy reach out for the dealer we used
I would not use the digital volume as a preamp but I'm superstitious about using digital volume past a certain point.
  • Like 1
The Brooklyn DAC+/Bridge has a very good HP out that you can use single ended or balanced. You do need an adapter for balanced, but that just gives the opportunity to buy more shit. I do want to hook it to the GSX when it returns.
You also have the option to use the volume as analog, digital or true bypass. I guess I’m a Mytek shill.
Edited by morphsci
  • Like 2
1 hour ago, jp11801 said:
Lumin just added LeedH volume control and they now state you can use the T2 volume control in place of a pre
I've gotten feedback from some people that the LeedH volume control is better than their preamp volume control, even via the Lumin digital output into a DAC. (I haven't tried that comparison yet.) And it's definitely better than the previous Lumin volume control algorithm.
  • Like 1
Got the Brooklyn Bridge this afternoon.  Still have a ton to figure out, but just listening to HiRes via Qobuz on old Emotiva power monitors I would say it is a hell of a DAC.  Shilling will begin soon with an unboxing video.  Stay tuned.
  • Like 14
Nice!
Pro Tip: If you have it attached via USB to a computer the Mytek Control Panel makes it much easier to change settings and do firmware upgrades. I use network streaming on mine for music playback but I have the Mac-mini attached via USB so I can use the control panel.
  • Like 1
I have the software on the computer.  Need to check the firmware version.
Also need to figure out how to use it as a streamer besides using Roon, which is the same damn thing as using USB since they are on the same computer.
Both Ethernet and WiFi can do up to 24/192 PCM and DSD64.  I am pretty sure I've played some DSD128 tracks on mine in the past, maybe it downsamples (?).  EDIT: I think Roon will downsample unsupported formats.....still sounds great.
Edited by skullguise
38 minutes ago, VPI said:
I must have a settings issue. Every time I try to play DSD I get a device cannot be initiated or some shit.
What software are you using? I can definitely play 24/192 PCM and DSD 64 directly to the Mytek over my network using Roon.
