unbalanced/balanced to balanced tube input
kevin gilmore
So I've been looking at a bunch of tube/solid state hybrid dynamic amp schematics, and every one of them is some form of bad, or really bad. (one person/ex company in particular)
Low voltage plate, capacitve coupling of a high impedance source into a low impedance, poor balance etc.
There had to be a better way. true balanced input. dc coupling. low impedance output. no feedback. proper use of a tube (pure transconducance) etc
so I came up with this, work in progress.  4 x 3 inches
ubaltobaltubeschem.PDF
  • Like 15
Looks a lot like the front end of an electrostatic headphone amp (T8000-ish), but with relatively low voltage transistors (except for the KSA1156).  You could always substitute a MOSFET current source for the input tube tail CCS. :D
Edited by JimL
  • Haha 1
  • 5 months later...
Since this is probably the first thing I will try from the group buy I wondered about the transformer and the VA. Looking at the input ac like this would couple 2 cheap transformers work? The +-15 is from a GRLV or something I guess or would a LM317+LM337  do the job?
Gonna build this from the group buy soon,
On the board the silkscreen says "tube mounts on the back side of the board" but tracing the boards shows it's the same version as the one in first post. So tubes should be mounted from the top?
I also have never built tube amps so I might be wrong.
some questions I have:
1. How hot is the mosfet on PSU will be? Will heatsinking with chassis floor (3mm aluminum) suffice or does it need heatsink?
2. LT1085 require heatsinks or not?
3. Will it make a good preamp? Do I need to watch/match it's output impedance to the amp's input?
4. How to bias it?
  • 4 weeks later...
I've compiled a BOM from Digikey for the supplied GRHV based on my silkscreen from the recent group buy board. I hope others can help check if I missed anything.
https://docs.google.com/spreadsheets/d/1XMu81oWk6E3mXPW6ahhEuvmhg4U497F5I5W6JPQgnNo/edit?usp=sharing
You might notice there's RES 90.9K and RES 1.10K, these are because I can't find 92K resistors sold without MOQ.
  • Like 1
  • 5 weeks later...
On 7/29/2018 at 9:29 AM, kevin gilmore said:
here are both of them, not sure which one was in the group buy
3)  Its a current mirror. So output voltage depends on impedance, currently 1100 ohms. Needs an output buffer if you are going to use it for a preamp.
Kevin, can I use the Diamond output buffer ver. 2.0 ?
  • 9 months later...
Dear Kevin,
I find the heater power supply portion to be rather handy.
Would you please  cut the HV supply portion away so  that I can use the heater power supply portion for mini T2 project?
Thanks
Sam
On 11/13/2017 at 7:45 AM, kevin gilmore said:
board files for you :D
updated including 100v massive overkill power supply
ubaltobaltube.zip
grhv100v.zip
Edited by samsie
  • 5 months later...
  • 3 years later...
