Constant pressure tube substitution
vertek
As best I can tell, I believe you are referring to zener diodes Z3 and Z4, which are 47volt rated in the SMR600, and presumably the same in the SRM007. It would be less confusing if you didn't make up your own names for components.
My guess is pressure = 压力 = 电压 = voltage?
stable pressure = 稳压 = voltage regulation?
So the whole thing translate to:
I'm gonna be rude here, but you will have to give me the answer.
Edited by lkong
