Kerry Design mini GRHV\GRLV and JoaMat mini T2 Group Buy
mwl168
10 hours ago, Energy said:
I would like one bare set please. Thank you!
Please read the thread and be specific about which boards you want and how many.
On 3/17/2020 at 12:12 AM, JoseA said:
I would like partially assembled boards for one set  Thank you
Please be specific.
Table updated.
Edited by mwl168
mwl168, I had a look at the bom for the gr78xx and tried to build a mouser project from it. However mouser says the kst42mtf is obsolete and out of stock. Also C3 C7 in the bom is the same as c1 and c2 but is on a seperate line... the gr79xx also uses the obsolete kst42mtf. the gr79xx also has two entries for the same cap, c1,c4 and the line c7.
Ok looks like farnell still has some stock remaining....
Edited by jamesmking
Hi
sorry for the delay but quite busy down here curing people with that damn virus (not infected yet !!! thanks to my own protection hardware ....)
i will double the order so 2 sets , that would be
4x GRHVxxx (assembled)
2x GRLV78xx
2x GRLV79xx
2x main board
2x mini t2 board
Right ?and obviously i confirm the participation :)
2 hours ago, jamesmking said:
mwl168, I had a look at the bom for the gr78xx and tried to build a mouser project from it. However mouser says the kst42mtf is obsolete and out of stock. Also C3 in the bom is the same as c1 and c2 but is on a seperate line... the gr79xx also uses the obsolete kst42mtf. the gr79xx also has two entries for the same cap, c1,c4 and the line c7.
C1, C2 and C3 are different values.
A quick look seems CMPTA42 could be a pin/package compatible part for KST42Same goes for the PNP part.
Kerry and others should be able to confirm.
Table updated.
Edited by mwl168
Table updated.
I think I've used MMBTA42/92 in the past successfully, though your suggestion Michael looks like it should work as well.
We have a few new comers to HC (<= 10 posts) that participated in this GB and have not responded to my inquiries, including direct PM, for confirmation. We need final board counts to get accurate quotes from the fab house for this GB to proceed.
The GB participants listed below please respond on this thread with your confirmation or desire to drop out by end of day this coming Sunday, March 22. If we do not receive your response , I will assume you are no longer interested and will remove you from the GB. Thanks!
stickyjon23
grendel23
zumac99
Marc Edwards
Edited by mwl168
4 hours ago, Makoto said:
Hi Michael,
hoping that I'm not too late, I would like to have
2x GRHVxxx
1x GRLV79xx
1x GRLV78xx
3x Main Board
3x miniT2
with much thanks!
Do you want the GRHVxxx partially assembled or bare boards?
I assume you know the PSU Main board is designed specifically to work with the GRHVxxx boards? Each main board takes 2 GRHVxxx boards to supply a set of  +/- HV rails.
Edited by mwl168
It's good for newbie to have the advice. I'd take the bare boards, then
6x GRHVxxx
3x GRLV79xx
3x GRLV78xx
3x Main Board
3x miniT2
Thanks!
