DIY amp and dac. Dynalo + GRLV psu + PCM1794A dac + CM6631A usb-i2s
jbozek
Hi! i would like to share my work with you. I made an dynalo amp powered by grlv power supply and a pcm1794a/cm6631a dac. Everything is totaly made by me. I also designed the pcb nd ordered it from JLCPCB. Amp offset voltage stays at max +-1mV and it is totally silent. Case is DOUK AUDIO.
pictures:
https://drive.google.com/drive/folders/1a6cbGFpN6s5EadR8DA_lb21ZFwOwzK4R?usp=sharing
  • Like 8
  • 2 months later...
