jpelg Posted July 28, 2021 Report Share Posted July 28, 2021 The end of a headphone plug broke off in one of my headphone amps that has a locking Neutrik 1/4" headphone jack. I tried the straw trick, and even the screw trick (gently), all to no avail. Considering the glue/heat trick. Am I fucked (and not in a good way), or is there another technique I should consider trying to get the piece out? Any inputs are appreciated. TIA. Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 28, 2021 Report Share Posted July 28, 2021 I dunno what those other tricks are as I've never had one break inside the jack, but the back of the locking jack is open so if there's room to get to it from inside the amp you can just push on the end of the broken plug with something while holding the release tab down. 3 Quote Link to comment Share on other sites More sharing options...
jpelg Posted July 28, 2021 Author Report Share Posted July 28, 2021 ^Ahhh...from the pictures I've seen of just the jack it appeared that it was sealed from the back. I will see if I can try that. Thank you! Quote Link to comment Share on other sites More sharing options...
n_maher Posted July 28, 2021 Report Share Posted July 28, 2021 I took a look at various product images (which refuse to be attached to this post thanks to my nonsense work network) and you should be able to press it out as Fitz suggests. I'm sure it'll take some messing about but looks like it should be a recoverable failure. Worse case, let us know what amp it is and we can look at how hard it'd be to replace the whole headphone jack. 2 Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 29, 2021 Report Share Posted July 29, 2021 The locking jacks can be partially disassembled to make it even easier to get the broken piece out, but it's real easy to lose the spring for the locking tab so I'd save that for a last resort before completely replacing it if that was necessary. It wasn't too hard to push a (non-broken) jack out from behind with a screwdriver when I tested it before posting. It'd even be possible to push it out the back from the front (the opening is big enough), but unless it's broken right at the tip, the locking tab will probably fight you on that. 1 Quote Link to comment Share on other sites More sharing options...
penmarker Posted July 29, 2021 Report Share Posted July 29, 2021 That's a beautiful clamp Fitz, do you have a link for that? Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 29, 2021 Report Share Posted July 29, 2021 4 minutes ago, penmarker said: That's a beautiful clamp Fitz, do you have a link for that? Panavise Jr. https://www.amazon.com/PanaVise-Model-Junior-Miniature-Vise/dp/B0819549KS 1 Quote Link to comment Share on other sites More sharing options...
swt61 Posted July 29, 2021 Report Share Posted July 29, 2021 48 minutes ago, penmarker said: That's a beautiful clamp Fitz, do you have a link for that? Oh, you ment that clamp on his desk. Nevermind. 1 Quote Link to comment Share on other sites More sharing options...
penmarker Posted July 29, 2021 Report Share Posted July 29, 2021 No no no, this.. this is nice. I should explore and experiment. Quote Link to comment Share on other sites More sharing options...
Fitz Posted July 30, 2021 Report Share Posted July 30, 2021 I thought I scrubbed that picture from the internet. 1 Quote Link to comment Share on other sites More sharing options...
swt61 Posted July 31, 2021 Report Share Posted July 31, 2021 Well, I did have the original. 1 Quote Link to comment Share on other sites More sharing options...
