sbelyo Posted September 30, 2021 Report Share Posted September 30, 2021 I'll soon have the need to switch between two different sources and amps and I'm two projects behind even starting my preamp. I want to put together a 2 in 2 out switch. If I use 4P2T switches how should I manage the shield (pin 1)? Or should I use 3P2T2D and not worry? I'm just trying to see if I can get away with 1 deck instead of two? Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted September 30, 2021 Report Share Posted September 30, 2021 I'm generally in favor of making things instead of buying them, but in this case you can buy such a thing for less than the cost of the parts. If you do build it, you should manage the shield the same as you would on any other project: https://www.ranecommercial.com/kb_article.php?article=2107 Quote Link to comment Share on other sites More sharing options...
sbelyo Posted September 30, 2021 Author Report Share Posted September 30, 2021 I agree... Goldpoint make a 1 in 2 out or 2 in one out for $395 That'd be about what it would cost to build what I'm taking about. I see lots of 4x1 and 1x4. Where else should I look? There's this https://www.amazon.com/Nobsound-Balanced-Converter-Audio-Selector/dp/B07D7P7366/ref=sr_1_10?dchild=1&gclid=Cj0KCQjwwNWKBhDAARIsAJ8HkhdVZLw63nCWM4jSmKFyh-5ElXROxIQhrO9XIg34HmDjhiCDc2hbdOsaApLkEALw_wcB&hvadid=474280920474&hvdev=c&hvlocphy=9003511&hvnetw=g&hvqmt=e&hvrand=15182943523645060152&hvtargid=kwd-309276109139&hydadcr=17980_10939357&keywords=balanced+audio+switcher&qid=1633030674&sr=8-10 Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted September 30, 2021 Report Share Posted September 30, 2021 https://www.amazon.com/ONE-Little-Bear-Balanced-Converter/dp/B00OY0TBMA/ref=mp_s_a_1_5?crid=2SQRY9IXA4C1Y&dchild=1&keywords=xlr+switch&qid=1633032455&sprefix=XLR+swi&sr=8-5 Same thing, same price, different brand Quote Link to comment Share on other sites More sharing options...
sbelyo Posted September 30, 2021 Author Report Share Posted September 30, 2021 lol, Amazon is too funny Quote Link to comment Share on other sites More sharing options...
audiostar Posted October 5, 2021 Report Share Posted October 5, 2021 Shield stays connected to the chassis only. Ground is pin 1. I use Neutrik's that have separate shield/chassis connection from ground and chassis goes back to the PSU where only there chassis connects to circuit ground and mains ground (in a star manner). So, in your example for the input I would only switch pin 2 and 3 (and not switch ground, nor shield) with a DPDT relay best, something like a a Kemet EC2-12NU (one per channel), located near the inputs on the back of the amp. A front located SPDT switch will only toggle the relays. The output I probably would not switch at all, but depending on the subsequent device (power on/off status) it will be the one or the another (or both, if you make sure you can use both outputs at the same time). Ofc, you can have the same switching for the output as on the inputs, one EC2-12NU per channel and switched by a front located simple SPDT switch. As you prefer. The above Kemet's are for 12V, check the voltage in your device or use MC78/79 type of voltage regulators or change relays to 5V,... 24V to suit your needs. Omron G6A-234P-ST-US relays might be used as well. Quote Link to comment Share on other sites More sharing options...
sbelyo Posted October 5, 2021 Author Report Share Posted October 5, 2021 1 hour ago, audiostar said: Shield stays connected to the chassis only. Ground is pin 1. I use Neutrik's that have separate shield/chassis connection from ground and chassis goes back to the PSU where only there chassis connects to circuit ground and mains ground (in a star manner). So, in your example for the input I would only switch pin 2 and 3 (and not switch ground, nor shield) with a DPDT relay best, something like a a Kemet EC2-12NU (one per channel), located near the inputs on the back of the amp. A front located SPDT switch will only toggle the relays. The output I probably would not switch at all, but depending on the subsequent device (power on/off status) it will be the one or the another (or both, if you make sure you can use both outputs at the same time). Ofc, you can have the same switching for the output as on the inputs, one EC2-12NU per channel and switched by a front located simple SPDT switch. As you prefer. The above Kemet's are for 12V, check the voltage in your device or use MC78/79 type of voltage regulators or change relays to 5V,... 24V to suit your needs. Omron G6A-234P-ST-US relays might be used as well. That makes sense to me. I figured I'd only switch pin 2 and 3. 1 Quote Link to comment Share on other sites More sharing options...
