Smeggy Posted February 24, 2008 Report Share Posted February 24, 2008 DIY Gods, I'm trying to find out if there are any good but not excessively expensive 3-way rotary speaker output selector switches available that any of you DIYers may know about. I'll also want a regular 3-way rotary input selector switch but have no idea which are decent and which are crap. My plan is to eventually integrate a Stax transformer, headphone transformer and regular speaker outs in an amp and want to have a nice big selector knob for them. That way I can have one integrated amp that can run anything I'm ever likely to own and have ample power to drive any and all difficult loads. Any recommendations? Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted February 25, 2008 Report Share Posted February 25, 2008 price range? I'd check out Michael Percy and if those are too expensive, try these: http://www.vt4c.com/shop/program/main.php?cat_id=60&group_id=2 Quote Link to comment Share on other sites More sharing options...
Smeggy Posted February 25, 2008 Author Report Share Posted February 25, 2008 Thanks for the reply, looking now. Would I be able to use the same switch type as both input selector and speaker selector or would the speaker one need to be a more beefy affair on something with up to 20 wpc or so? Quote Link to comment Share on other sites More sharing options...
n_maher Posted February 25, 2008 Report Share Posted February 25, 2008 Either DigiKey or Mouser carries some very nice Grayhill switches, I've got one at home and will look up the part number for you tonight. Quote Link to comment Share on other sites More sharing options...
Smeggy Posted February 25, 2008 Author Report Share Posted February 25, 2008 Thanks Quote Link to comment Share on other sites More sharing options...
n_maher Posted February 25, 2008 Report Share Posted February 25, 2008 Check the Electroswitch C4 Series that is carried by Mouser. You should be able to configure that to fit your needs. Ask if you need help. Quote Link to comment Share on other sites More sharing options...
thrice Posted February 25, 2008 Report Share Posted February 25, 2008 Check the Electroswitch C4 Series that is carried by Mouser. You should be able to configure that to fit your needs. Ask if you need help. I've used those before, they're just fine....make sure you get solder lug termination and not PC board termination. The solder lug is a little loop of metal you thread your wire through and solder...the PC Board termination is a straight piece of metal that would go into a printed circuit board. You can still attacha wire to it, but it becomes a pain in the ass. Quote Link to comment Share on other sites More sharing options...
Smeggy Posted February 25, 2008 Author Report Share Posted February 25, 2008 Good to know and thanks again. Just getting all the options I may need in line. Quote Link to comment Share on other sites More sharing options...
