Luxman P1u
Continual effective output 2W+2W/8Ω, 1W+1W/16Ω, 500mW+500mW/32Ω and 27mW+27mW/600Ω
Input sensitivity/input impedance
unbalanced: 1.0V/26KΩ and balanced: 1.0V/67KΩ
Total harmonic distortion 0.0025% (1KHz), 0.02% (20Hz~20KHz)
Frequency range 20Hz~20KHz (+0, - 0.1dB), 5Hz~170KHz (+0, - 3.0dB)
Signal-noise ratio 115dB (IHF-A)
Input/output
Input: 1 balanced pair, 1 unbalanced pair
Output: 2 headphone jacks and 1 through φ6.3 RCA jack
Power/dimension/weight: 19W/40 (W)
  • Replies 64
That's a bit disappointing. It doesn't seem like a big upgrade over the P-1 if it can be called an upgrade at all.
I guess Luxman America's going to sell it for $3000, more because of where the yen is in relation to the dollar today than because of improvements made to the design.
For reference, these are the P-1 mkI specs
Continuous Rated Output
4W+4W/8Ω and 2W+2W/16Ω,
1W+1W/32Ω and 500mW+500mW/64Ω,
53mW+53mW/600Ω
Input Sensitivity / Impedance
1.0V/23KΩ balance 1.0V/66K
Total Harmonic Distortion
0.008% or less (1kHz), 0.025% or less (20~20kHz)
Frequency Response
20~20Hz (+0, - 0.1dB), 10~100kHz (+0, - 0.5dB)
Signal-To-Noise Ratio (IHF-A)
Above 108dB
Inputs
One pair of RCA sockets,
One pair of Balanced sockets on XLR.
Outputs
3 outlets - quarter inch standard headphone jacks
Volume, Balance controls, Balance Control Bypass Switch, Input selector switch,
Power switch, power source on (protection) indicator,
Balanced & UnBalanced Inputs, Line Phase Sensor, AC inlet
Electric Power Consumption
31W
Dimensions W x H x D
16.4"(467)
  • 4 weeks later...
I got a email from on a higher note yesterday with the following information
"Luxman are replacing the P-1 reference headphone amplifier with the P-1u; another class A design, the P-1u features ODNF 3.0 and is more than four times quieter than its predecessor. We are expecting our first shipment of the P-1u in September @ $3,000; these are expected to sell out quickly as initial supplies will be limited."
Getting pretty expensive there. Wonder will the pricing on the original P1 will drop to 2k.
