spritzer
is this g code? or is there a special way to do step and repeat?
I was trying to get cute. (meaning lazy...)
I got it right on the 3rd try.
Anyway
http://gilmore.chem.northwestern.edu/staxjack4.jpg
I could make it bigger, and keep the rest of it the same size, but i'm not
sure why i would want to. Then if someone really did want to put in a he90
jack, they would have to make a sleeve.
As far as mounting them, i really was planning on thru holes. But i'll try some
blind holes on test aluminum first to see if i like how much bite there is going to
be. It would definitely look cooler to have blind holes. So far i have managed
not to have any blind holes.
The price is still going to be ugly unless luvdunhill comes thru with the pins on
the cheap. Its really only about $5 in teflon per jack, plus machining time.
Plus $19 for the octal socket to steal the pins from.
It does not matter, i want it perfect.
Right now machines like the hurco and fadal can be had used with full warranty
for something like 20% of retail. So many companies going out of business due to
the economy, that there is a huge glut of these things. You can actually get
stuff like this that will fit in a standard garage, and run on single phase for
about $7k with a full set of tool holders for the tool bank and a number of different
hold down bars and a massive vise or two.
Then just add software, and any trained monkey can do this.
I wonder if my friend in skokie is trainable?
featurecam, solidworks, or captiva is what you are looking for.
There are certainly lots of others. Some software is CAD only, like autocad,
some software is CAM only. Featurecam is both. And made especially easy
because it sucks in many 3D formats, for the ultimate in quick and brain dead.
Make sure that you pick software that already has a post-processor for the
machine you are going to acquire. Even a shitty post-processor can make
a big difference in how long it takes to actually make something.
Kevin, Marc designed some faceplates for my Beta22/Sigma22 that have blind holes in 4mm aluminum, and they have plenty of bite. They look so clean that I'm really glad he did them that way.
Working on it!
Really...
Wanted the front panel by tomorrow, but i'm just too tired.
(burning the candle at both ends on a newly funded 5.6M$ NIH grant)
(5 years of programming all in about 3 weeks :D)
(there seem to be a few minor bugs)
ultra high quality mil-spec shaft coupler available from RSA for $35.
Same as in the stealth.
http://gilmore.chem.northwestern.edu/rk50shaft.jpg
Also available from mouser for $1.92 plus about 30 seconds in my lathe in
my basement. Non-magnetic oxygen free brass, chrome plated. :D
Now the lunatic master machinist suggested i precision machine the holes for
the stax jack mounting screws, then insert machined and threaded pins with
a drop of super glue.
So i will be blind hole tapping for 4-40, as i believe that will be sufficient.
Also shown the tulip pins from marc.
The pins I sent Kevin are slightly different shape from the ones I previously had. From head on, they look slightly less substantial and you'd think they would have less force on the pins. However, I have a feeling this is aesthetic only, as I cannot tell the difference in a controlled double-blind test ;)
I told Kevin I'd be glad to source these for everyone. I have a family member that can pick them up and mail them to me at a pretty reasonable cost, if I'm not able to supply them from my current stash.
I can also get a quote on the 9-pin sockets, and 8-pin sockets.
So some people are picking on me for what they seem to believe is my lack of
ability to use a camera. Yes there really are differences between quickpics done
at night handheld with a flash, and waiting for the sun to show up.
ok, so here is the original
http://gilmore.chem.northwestern.edu/staxjack3.jpg
and here is the same thing with daylight, f32 6 seconds exposure
due to the lens, everything is out of focus. I tried, but this was the
best picture i could get.
http://gilmore.chem.northwestern.edu/staxjack3f32.jpg
and here is the same thing f16 3 seconds
this is probably the best this lens can do.
http://gilmore.chem.northwestern.edu/staxjack3f16.jpg
and here is the same thing f8 about 1.5 seconds
http://gilmore.chem.northwestern.edu/staxjack3f8.jpg
Mounted on a 50 lb tripod, camera completely secured, RF remote trigger
focus set once. Notice the picture shift with f-stop. That is NOT
the camera moving. Of course none of these could be done handheld.
So in the future you will continue to see quickpics due to me being a lazy fart
until the thing is done, then the pictures will be perfect.
Its the sound... stupid :D
Kinda sensitive aint'cha...
Please get a quote on the sockets for us.
I'm with Birgir, for at least enough to build this.
Who on earth could possibly find fault with your large detailed pics?
I like the first one(the original) best.
everyone is a critic.
OK, now on to what will probably be pages and pages of discussion on the
most important aspect of the amplifier.
The KNOB. (pronounced 'KaNOBB")
So i've been playing with the delrin shaft on the panel bearing, and it acts just
like the real T2. Which is to say, it binds and generally sucks.
So its blind hole time again. Since i don't want any visible setscrew holes, i think
its best to machine the knob as one piece with a .875 shaft, and then the
panel bearing will work perfect.
Now on to the discussion of the diameter and thickness of the knob.
If i exactly center it, which i now think i'm going to do, the diameter can be
as big as 2.9525 inches. But i think that is a bit big. So something like
1.5 x 1 inch??
Kevin, do you have a drawing or picture of the face plate? I'm generally in favor of big KaNOBBs but I agree that nearly 3" seems too large. Seeing the plate layout and dimensions could help though.
Should have the real thing in a couple of days. Panel is 2.957 high and i don't remember
how wide, look at the pictures.
All that is on it is the volume knob in the middle and 2 of my stax jacks mounted
via blind holes from the back. Vertically in line with the output tubes.
(i.e. 2.575 + and - from exact center)
