chinsettawong Posted November 19, 2014 Report Share Posted November 19, 2014 I agree with Spritzer that all you'll have to do is to open it up to clean it. Quote Link to comment Share on other sites More sharing options...
n3rdling Posted November 20, 2014 Report Share Posted November 20, 2014 There's too much mysticism surrounding Stax drivers. It didn't sound like your problem would ever result in "a bad diaphragm that needs replacing". Open them up in as clean an environment as you can manage and get the dust/hair off the membrane. You have buzzing so there's something small creating an arc...if you had channel imbalance that'd be a different story. Quote Link to comment Share on other sites More sharing options...
johnwmclean Posted November 20, 2014 Report Share Posted November 20, 2014 There's too much mysticism surrounding Stax drivers. It didn't sound like your problem would ever result in "a bad diaphragm that needs replacing". Open them up in as clean an environment as you can manage and get the dust/hair off the membrane. You have buzzing so there's something small creating an arc...if you had channel imbalance that'd be a different story. x 2 good luck TMoney! Quote Link to comment Share on other sites More sharing options...
DefQon Posted November 20, 2014 Report Share Posted November 20, 2014 (edited) Pardon me but my head is ringing, If I read that correctly, you spent for example $3k for a 009 which developed a high pitch noise, you sent it to Yama's for repair. Yama has gotten back and quoted $2950 for a repair or you can buy a new pair straight from them for $3250? So original 009 + new/repaired 009 = nearly $6k? $2000 for a pair of drivers bit excessive me thinks :/ Edited November 20, 2014 by DefQon Quote Link to comment Share on other sites More sharing options...
wink Posted November 20, 2014 Report Share Posted November 20, 2014 it's like building a car by buying the parts at retail price. Quote Link to comment Share on other sites More sharing options...
spritzer Posted November 20, 2014 Report Share Posted November 20, 2014 Stax always charge way too much for the drivers. Not as bad as Sennheiser but still... Quote Link to comment Share on other sites More sharing options...
TMoney Posted November 20, 2014 Report Share Posted November 20, 2014 Thanks for all the advice, gang. I emailed Yama's back to see if they can't be a little more flexible on the prices they sent me. I will have to ask them about the possibility cleaning the damaged driver as well. Given that they communicate at the speed of a carrier pigeon, I hope to hear back from them in the next 2-4 weeks. It was good to take a night to sleep on it. When I first got the email I was ready to throw something across the room. 1 Quote Link to comment Share on other sites More sharing options...
Tachikoma Posted November 20, 2014 Report Share Posted November 20, 2014 What n3rdling said, and use sticky tape to get dust off the stators as well. Just do it yourself imo, if only to save time. Quote Link to comment Share on other sites More sharing options...
nopants Posted November 20, 2014 Report Share Posted November 20, 2014 (edited) I think mentioned this a few other times, but there's a giotto air blotter which I've used in the past. Is sticky tape reliable? I've been meaning to take my squealing pair apart to deal with some of the debris present. Edited November 20, 2014 by nopants Quote Link to comment Share on other sites More sharing options...
Tachikoma Posted November 20, 2014 Report Share Posted November 20, 2014 (edited) Very. My loudly squealing drivers were dead silent after I went through them with some sticky tape. I washed my membranes in water and recoated them before, though. Disclaimer: I wouldn't recommend washing and recoating the 009 membranes. it took me a great number of tries before I could get them balanced, and now the drivers are normal bias only. Re:cleaning the diaphragm. I did have good results from lightly wiping the membranes with my finger, but again, probably not a good idea with a 009 Edited November 20, 2014 by Tachikoma Quote Link to comment Share on other sites More sharing options...
nopants Posted November 20, 2014 Report Share Posted November 20, 2014 This would be for the 007s so I think I'll have to keep it at tape. I was wary of doing this because I figured if I used something silly like packing tape I could end up ripping the dust cover off Quote Link to comment Share on other sites More sharing options...
Tachikoma Posted November 21, 2014 Report Share Posted November 21, 2014 Yeah, if you're clumsy the way I am, small strips of tape are the way to go... wouldn't want to accidentally get tape on the membranes/dust cover. Chances are the dust cover has a hole somewhere too, so try to patch that if you can. Quote Link to comment Share on other sites More sharing options...
n3rdling Posted November 21, 2014 Report Share Posted November 21, 2014 Re: using tape, I'd recommend a weak tape like scotch. Strong enough to pick up debris and too weak to do any damage. Quote Link to comment Share on other sites More sharing options...
Laowei Posted November 21, 2014 Report Share Posted November 21, 2014 Maybe the sticky side of a post it note? That's a fairly mild adhesive. Quote Link to comment Share on other sites More sharing options...
nikongod Posted November 21, 2014 Report Share Posted November 21, 2014 Maybe the sticky side of a post it note? That's a fairly mild adhesive.This.Or 3M blue-painter's tape.Both have very gentle adhesive.I would be worried about scotch tape. Too sticky me thinks. Quote Link to comment Share on other sites More sharing options...
DefQon Posted November 21, 2014 Report Share Posted November 21, 2014 Cheap scotch tape is sticky. The better brands such as 3M and others available in professional painter stores do the job too. Quote Link to comment Share on other sites More sharing options...
Tachikoma Posted November 21, 2014 Report Share Posted November 21, 2014 I'm not sure why the tape being too sticky would be a big problem, you're applying it on metal stators, not plastic. I felt that the most difficult thing about cleaning out the stators was to not overstress the bias connector that connects the two sides of the drivers. Quote Link to comment Share on other sites More sharing options...
spritzer Posted November 21, 2014 Report Share Posted November 21, 2014 I'd never, ever touch the diaphragm with my bare fingers. Nothing good can come of that. The tape can leave residue which can arc the drivers. You need something that is sticky but takes next to no force to remove. Quote Link to comment Share on other sites More sharing options...
nopants Posted November 21, 2014 Report Share Posted November 21, 2014 post it it is, plus points for being able to steal them from the office Quote Link to comment Share on other sites More sharing options...
Tachikoma Posted November 22, 2014 Report Share Posted November 22, 2014 I'd never, ever touch the diaphragm with my bare fingers. Nothing good can come of that. The tape can leave residue which can arc the drivers. You need something that is sticky but takes next to no force to remove. It was an utterly fubar set of drivers, so I had no qualms doing that - it did solve the problem though. My thinking was that fingers leave no residue (other than a little oil), aren't overly abrasive and are sensitive to boot. There was a surprising amount of dust stuck on the membrane, which I could feel with my finger, that simply would not come off any other way, besides sticking it under running water. Yeah, tapes that leave as little residue as possible would be good. Quote Link to comment Share on other sites More sharing options...
Torpedo Posted November 22, 2014 Report Share Posted November 22, 2014 What about the adhesive band in the Post-it paper tags? Quote Link to comment Share on other sites More sharing options...
HeadphoneAddict Posted November 23, 2014 Report Share Posted November 23, 2014 I'd never, ever touch the diaphragm with my bare fingers. Nothing good can come of that. The tape can leave residue which can arc the drivers. You need something that is sticky but takes next to no force to remove. How about one of those washable reusable sticky rollers that you run over an album (LP) to get the dust out of the grooves? Quote Link to comment Share on other sites More sharing options...
TMoney Posted November 24, 2014 Report Share Posted November 24, 2014 Sorry to disappoint everyone who wanted to see the 009s dissected, but I'm going to take the easy way out. Yama's ended up negotiating the trade-in price for a new pair down to a number I could stomach. It will be below what a new pair would have cost from PJ, but my wallet is still going to be absolutely crushed for the foreseeable future. Heres hoping for an X-mas bonus at work. Quote Link to comment Share on other sites More sharing options...
Torpedo Posted November 24, 2014 Report Share Posted November 24, 2014 It seems a good decision too, so well done Quote Link to comment Share on other sites More sharing options...
nopants Posted November 25, 2014 Report Share Posted November 25, 2014 post-its work well but I somehow ended up messing up the left and right channel imbalance, a good 6db difference between the two. I was thinking the dust covers around the driver might be sticking together or something, is this possible? When I press the cups against my head I can hear the balance fixing itself momentarily. Sorry if this sounds a bit repost-y, this is the original condition in which I received the headphones. Quote Link to comment Share on other sites More sharing options...
