ktm Posted January 23, 2018 Report Share Posted January 23, 2018 If it passes the Spritzer test, it will have passed the hardest one. Good luck!!!!!!!!!! 1 Quote Link to comment Share on other sites More sharing options...
Jon L Posted January 23, 2018 Report Share Posted January 23, 2018 On 1/22/2018 at 12:01 AM, vvar10ck said: Good day everyone! Unfortunately Head-fi topic of Perun was deleted and they're requested for a sponsorship, it's from 1K $ per month and too expencive for us. Feel free to contact me via PM or http://perun.prfi.ru mentioned above. Is that amp your company's amp? It doesn't seem to be on your website and says "Flux Lab" on it? Quote Link to comment Share on other sites More sharing options...
vvar10ck Posted January 23, 2018 Report Share Posted January 23, 2018 (edited) It's KGBH SE (Analog Edition) made by Flux Lab Acoustics. http://fluxlab-acoustics.com/Products/18 I'm usin' it for my personal enjoyment with ES headphones. Edited January 24, 2018 by vvar10ck remarks added 1 Quote Link to comment Share on other sites More sharing options...
HemiSam Posted January 23, 2018 Report Share Posted January 23, 2018 this is going to get colorful.... HS 2 Quote Link to comment Share on other sites More sharing options...
wink Posted January 24, 2018 Report Share Posted January 24, 2018 (edited) 7 hours ago, vvar10ck said: It's KGBH SE (Analog Edition) made by Flux Lab Acoustics. http://fluxlab-acoustics.com/Products/18 Does this mean the design is still in flux..... I looked at the site, but it was all Greek Russian to me....... Google Translate to the rescue....... Quote (MODEL DISMISSED / MODEL DISCONTINUED) FLUX LAB KGBH SE Hybrid amplifier for electrostatic headphones Bodes well...... Quote Amplifier for true connoisseurs of music! This model is an evolution of development, already well-proven design of the amplifier for electrostatic headphones - KGBH. The author of the circuit solution is a great enthusiast of electrostatic sound - Kevin Gilmour. Inspired by the legendary STAX SRM-T2 amplifier, he used a similar balanced output stage for electron tubes in his development of a semiconductor amplifier. This made it possible to obtain a high amplitude of the output signal with small distortions and a broad band of sound signal.This model is assembled with two types of volume control. The basic version of the regulator is a relay type attenuator using signal relays of the Japanese company Fujitsu Takamisawa, in the version of "Analog" - a high-quality attenuator of the transformer type is installed. In the design of the amplifier used attenuators of the English company Sowter, and for switching the terminals of the transformer controller uses a precision galette switch Swiss company Elma.Also in the configuration with a transformer attenuator, it becomes possible to use this model as a passive preamplifier.Specifications Band of reproduced frequencies: 5Hz-100kHz -0.1dB 0Hz-180kHz -3dB 10Hz-120kHz -3dB (Analog) Harmonic distortion: <0.01% The amplitude of the output signal is 1600V (peak-peak) Gain: 60dB Standard bias voltage: 580V (Pro) Input connectors: XLR (two inputs), RCA (two inputs) Power supply: AC 230V, 50 / 60Hz Power Consumption: 180W Dimensions: 440mm (W), 325mm (D), 180mm (H) Excluding the height of the lamps. Weight: 16kg Applied electronic lamps in the amplifier: 4 things. EL34 (6CA7)Flux Lab Acoustics © 2009-2018 "Kevin Gilmour" this must be the Cyrillic spelling....... " Кевин Гилмор"...... Sounds moar exotic...... Quote Also in the configuration with a transformer attenuator, it becomes possible to use this model as a passive preamplifier. How about that, folks, a 180 Watt Passive pre-amp................. Edited January 24, 2018 by wink Quote Link to comment Share on other sites More sharing options...
SeaWolf Posted January 24, 2018 Report Share Posted January 24, 2018 (edited) 53 minutes ago, wink said: How about that, folks, a 180 Watt Passive pre-amp................. Hey you could get there.. just do a normal passive preamp and stick the Megatrons tube complement on top and run the heaters. I mean it would look pretty? right Edit:: OMG I just started imagining the tube rolling options.. Edited January 24, 2018 by SeaWolf 1 Quote Link to comment Share on other sites More sharing options...
DefQon Posted January 24, 2018 Report Share Posted January 24, 2018 First off fuck Jude and head-fi, if you really want a good reception for your electrostats, talk to folks who are very intimate with e-stat gear, Birgir (aka spritzer), Kevin and Wachara, if you pass the test and take on feedback for any constructive criticism (feedback) from them, then I'm sure people will like what they will hear. Before any of this happens, you have to cut the bullshit first followed by facts. Though I have to be honest, the headphones do look kind of cheaply designed and built. 1 Quote Link to comment Share on other sites More sharing options...
vvar10ck Posted January 24, 2018 Report Share Posted January 24, 2018 12 minutes ago, DefQon said: Though I have to be honest, the headphones do look kind of cheaply designed and built. It's an Perun maker's view. Design conseption is very distinctive and pagan as Perun is old slavic 'God of thunder and lightning'. These headphones are totaly handmade of natural materials as ash tree, and natural skin (lambskin) etc. This design is antipode of modern 'eco-sh*t-leather' imitation and plastic parts. 1 Quote Link to comment Share on other sites More sharing options...
DefQon Posted January 24, 2018 Report Share Posted January 24, 2018 I like that you’re using wood for the cup but not a huge fan of the headband used which are reminiscent of the old 60-80’s quadraphonics Japanese and US made headphones.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
vvar10ck Posted January 24, 2018 Report Share Posted January 24, 2018 'For the taste and color all felt-tip pens are different for all people' :^) 1 Quote Link to comment Share on other sites More sharing options...
SeaWolf Posted January 24, 2018 Report Share Posted January 24, 2018 19 minutes ago, DefQon said: First off fuck Jude and head-fi, if you really want a good reception for your electrostats, talk to folks who are very intimate with e-stat gear, Birgir (aka spritzer), Kevin and Wachara, if you pass the test and take on feedback for any constructive criticism (feedback) from them, then I'm sure people will like what they will hear. Before any of this happens, you have to cut the bullshit first followed by facts. Though I have to be honest, the headphones do look kind of cheaply designed and built. Spritzer may seem to be very abrasive at first. But look at what he had to say about the phenomenon libratum on its thread here. He was actually quite complementary about the sound signature. And measured in his criticism of day to day design issues. He is less measured when fan boys declare it the best thing since sliced bread. That's more on the fan boys than the headphone but may not come across was such. Quote Link to comment Share on other sites More sharing options...
Kattefjaes Posted January 28, 2018 Report Share Posted January 28, 2018 Well, because I am credulous and vulnerable to hype trains (and have been peeping pictures of the drivers) I find myself wanting some L300-LE. Any thoughts about the best way to snag a pair in the UK when available? If it's just a case of telling a friendly dealer to keep an eye out, that's fine- but if there's a better way, I'm mostly ears. Quote Link to comment Share on other sites More sharing options...
morphsci Posted January 28, 2018 Report Share Posted January 28, 2018 On 1/24/2018 at 12:59 AM, vvar10ck said: 'For the taste and color all felt-tip pens are different for all people' :^) You can use google translate Quote Link to comment Share on other sites More sharing options...
swt61 Posted January 28, 2018 Report Share Posted January 28, 2018 Or just use the door. Quote Link to comment Share on other sites More sharing options...
Torpedo Posted January 28, 2018 Report Share Posted January 28, 2018 14 minutes ago, swt61 said: Or just use the door. Yeah, the back one Quote Link to comment Share on other sites More sharing options...
guzziguy Posted January 28, 2018 Report Share Posted January 28, 2018 That's the one that Steve mostly uses. 2 1 Quote Link to comment Share on other sites More sharing options...
padam Posted February 9, 2018 Report Share Posted February 9, 2018 With the latest batch of SR-009 headphones (SZ9-4xxx), it seems that Stax has changed the wooden box. So far I've spotted only two sets like that out of dozens. The question is whether they've tweaked them in any way, or they are exactly the same as before. Quote Link to comment Share on other sites More sharing options...
spritzer Posted February 9, 2018 Report Share Posted February 9, 2018 That's a good point. Knowing Stax they might have changed something but I haven't heard anything... The imbalance issue is certainly still there though. Quote Link to comment Share on other sites More sharing options...
Audiojunkie Posted February 10, 2018 Report Share Posted February 10, 2018 I owned a pair for about 6.5 years, never had an issue with my pair. Funny how some pair are totally unaffected and some had issues. Do we know what the root cause is yet? Quote Link to comment Share on other sites More sharing options...
justreadingup Posted February 10, 2018 Report Share Posted February 10, 2018 2 hours ago, Audiojunkie said: I owned a pair for about 6.5 years, never had an issue with my pair. Funny how some pair are totally unaffected and some had issues. Do we know what the root cause is yet? Quote Link to comment Share on other sites More sharing options...
spritzer Posted February 10, 2018 Report Share Posted February 10, 2018 There are a few parts to this, partially it is charge leakage, partially it is mechanical and finally...it has to be a coating issue as well. 1 Quote Link to comment Share on other sites More sharing options...
opt1mist Posted February 10, 2018 Report Share Posted February 10, 2018 Phenomenon Libratum ( updated the design ) Quote Link to comment Share on other sites More sharing options...
Laowei Posted February 10, 2018 Report Share Posted February 10, 2018 Which “update”? Quote Link to comment Share on other sites More sharing options...
Kattefjaes Posted February 10, 2018 Report Share Posted February 10, 2018 (edited) The "I registered to shill this" update, probably. (Looks like heavier mesh on the outside, and painted black? Now they look a touch more Abyss/S&M and a bit less like SR-007s) Edited February 10, 2018 by Kattefjaes 1 Quote Link to comment Share on other sites More sharing options...
spritzer Posted February 10, 2018 Report Share Posted February 10, 2018 Still no strain relief on the cables which is not great... 1 Quote Link to comment Share on other sites More sharing options...
