luvdunhill Posted January 11, 2011 Report Share Posted January 11, 2011 Now with more BLUE! Quote Link to comment Share on other sites More sharing options...
n_maher Posted January 11, 2011 Report Share Posted January 11, 2011 Very cool! If I may ask, how much did the powder coating set you back? Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted January 11, 2011 Author Report Share Posted January 11, 2011 Now with more BLUE! Not much traffic in this thread lately. . Just to keep everyone in the loop, we are waiting on a vendor. But, I think we are getting close ... Quote Link to comment Share on other sites More sharing options...
Pars Posted January 12, 2011 Report Share Posted January 12, 2011 Now with more BLUE! Looks good Marc. Just needs a blue LED Quote Link to comment Share on other sites More sharing options...
Kerry Posted January 12, 2011 Report Share Posted January 12, 2011 Really cool! Quote Link to comment Share on other sites More sharing options...
Fitz Posted January 12, 2011 Report Share Posted January 12, 2011 Hmm... reminds me I still need to try to deal with the dang buzz on the power transformer. Filling the obvious gap in the lams with some superglue didn't seem to do the trick. :/ Quote Link to comment Share on other sites More sharing options...
Fitz Posted January 14, 2011 Report Share Posted January 14, 2011 Could the problem be with the shield or something, instead of just the lams? I've been letting it run today and after the buzzing started, barely even touching it at all on the one corner would make it stop, and after pressing firmly around on the foil, it's stopped (at least for now). Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted January 15, 2011 Author Report Share Posted January 15, 2011 Transformers vibrate, so anything loose that could rattle due to that vibration could be causing your noise. Quote Link to comment Share on other sites More sharing options...
TomB Posted January 17, 2011 Report Share Posted January 17, 2011 (edited) OMG, Marc! That's fantastic!! P.S. Umm ... who's the audience behind some of those pics? Looks like some of the folk on top of my daughter's piano ... or maybe it's someone I saw in Clash of the Titans? Edited January 17, 2011 by TomB Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted January 17, 2011 Report Share Posted January 17, 2011 Thanks! Nate it was around $120 and they could have done three complete cases for that price. Tom, that would be Homer and Plato in fact Quote Link to comment Share on other sites More sharing options...
HiGHFLYiN9 Posted January 18, 2011 Report Share Posted January 18, 2011 (edited) Just to keep everyone in the loop, we are waiting on a vendor. But, I think we are getting close ... Great, really looking forward to building this luvdunhill I really dig the venting! I have a local powdercoater here that colors whatever items I've left with him on the side when he has a "real order" to take care of. He usually charges ~$40 an item or around $100 for a small box of stuff. I just had him handle an old Dynaco PAS2 that I'm rebuilding. Edited January 18, 2011 by HiGHFLYiN9 Quote Link to comment Share on other sites More sharing options...
drclaw Posted February 6, 2011 Report Share Posted February 6, 2011 Wow, this build looks pretty awesome! I can't wait until it makes it to production! Quote Link to comment Share on other sites More sharing options...
stringgz301 Posted February 12, 2011 Report Share Posted February 12, 2011 Definitely interested in building this. Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted February 13, 2011 Report Share Posted February 13, 2011 Hmm... reminds me I still need to try to deal with the dang buzz on the power transformer. Filling the obvious gap in the lams with some superglue didn't seem to do the trick. :/ Buzzing transformers are caused by incorrect manufacture in the first place. The only way to shut one up is to decouple it from the chassis big time. Assuming for the moment that it is a toroid, first take it out. Then make a vey thick layer of RTV - maybe 3/8" or so - and gently seat the transformer onto it. Make sure it does not squeeze out. When that has set somewhat, make a similar layer on the top and set the clamping washer on it. Put the bolt through to keep it lined up. When everything has set, nip the bolt up. The transformer is now vibration isolated from the chassis via two thick resilient layers. A similar thing can also be done with EI core transformers of course, but it would need some extra thought about how to deal with the bolt fixings. Using rubber grommets instead might work fine and is quick to try out. Precautions - try to chose an RTV that will cope with a transformer temperature of 60C. Quote Link to comment Share on other sites More sharing options...
Fitz Posted February 14, 2011 Report Share Posted February 14, 2011 Buzzing transformers are caused by incorrect manufacture in the first place. The only way to shut one up is to decouple it from the chassis big time. Assuming for the moment that it is a toroid, first take it out. Then make a vey thick layer of RTV - maybe 3/8" or so - and gently seat the transformer onto it. Make sure it does not squeeze out. When that has set somewhat, make a similar layer on the top and set the clamping washer on it. Put the bolt through to keep it lined up. When everything has set, nip the bolt up. The transformer is now vibration isolated from the chassis via two thick resilient layers. A similar thing can also be done with EI core transformers of course, but it would need some extra thought about how to deal with the bolt fixings. Using rubber grommets instead might work fine and is quick to try out. Precautions - try to chose an RTV that will cope with a transformer temperature of 60C. A quick glance at the first page would show there's no toroidal transformers in this amp , but an interesting solution nonetheless. I actually did track down the problem though, there was another gap in the lams that you could only tell it was there by looking at a specific angle; sealing it up took care of the problem nicely. Very nice to be able to listen to this amp regularly now. Now I have no excuse not to get off my butt and finish the chassis. Quote Link to comment Share on other sites More sharing options...
Pars Posted February 14, 2011 Report Share Posted February 14, 2011 Good you found a fix other than a new transformer! Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted February 19, 2011 Author Report Share Posted February 19, 2011 I actually did track down the problem though, there was another gap in the lams that you could only tell it was there by looking at a specific angle; sealing it up took care of the problem nicely. Good to hear you solved this. And, good to know that we need to check each of these transformers individually before sending them out. Quote Link to comment Share on other sites More sharing options...
Pars Posted February 19, 2011 Report Share Posted February 19, 2011 How are you guys coming along on the production version Doug? I was just over at my brother's briefly yesterday, and he is still enjoying his immensely. Thanks for letting me in on the proto phase! Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted February 19, 2011 Author Report Share Posted February 19, 2011 How are you guys coming along on the production version Doug? I was just over at my brother's briefly yesterday, and he is still enjoying his immensely. Thanks for letting me in on the proto phase! Basically, the only step left is telling the case manufacturer to go ahead and start. That should happen this week ... I think. Quote Link to comment Share on other sites More sharing options...
HiGHFLYiN9 Posted March 9, 2011 Report Share Posted March 9, 2011 (edited) Any updates on the production version? Edited March 9, 2011 by HiGHFLYiN9 Quote Link to comment Share on other sites More sharing options...
HiGHFLYiN9 Posted April 7, 2011 Report Share Posted April 7, 2011 (edited) Thread's dead, baby. Edited April 7, 2011 by HiGHFLYiN9 Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted April 8, 2011 Author Report Share Posted April 8, 2011 No, not dead, just delayed. We have, in hand, what we hope to be the final revision of the PCB -- it is now 14" long. We are waiting on a prototype of the final case, which we thought would have arrived already. Probably in the next week -- other cases ordered at the same time from the same vendor are in transit, so this one can't be far behind. There were only two of the final prototype boards made. Tom is building one, but if anyone (HiGHFLYiN9) wants to do the other, I also have a set of the transformers and a blank 14" case. Whomever wants it can have it for cost. Quote Link to comment Share on other sites More sharing options...
Lil Knight Posted April 8, 2011 Report Share Posted April 8, 2011 Would it be possible to buy just the PCB (and transformer, if possible) later when it's out? Quote Link to comment Share on other sites More sharing options...
HiGHFLYiN9 Posted April 8, 2011 Report Share Posted April 8, 2011 Thanks for the offer Doug. It's tempting, but I'll hold tight until the final package is available. Thanks for updating btw. Quote Link to comment Share on other sites More sharing options...
stringgz301 Posted April 16, 2011 Report Share Posted April 16, 2011 I'd love to build another proto. Drop me a pm with total cost. Thanks - No, not dead, just delayed. We have, in hand, what we hope to be the final revision of the PCB -- it is now 14" long. We are waiting on a prototype of the final case, which we thought would have arrived already. Probably in the next week -- other cases ordered at the same time from the same vendor are in transit, so this one can't be far behind. There were only two of the final prototype boards made. Tom is building one, but if anyone (HiGHFLYiN9) wants to do the other, I also have a set of the transformers and a blank 14" case. Whomever wants it can have it for cost. Quote Link to comment Share on other sites More sharing options...
