i'm on a roll... the kgsshv
kevin gilmore
Yea there are six 100k resistors on this board total. I'll probably just make another smaller order with mouser after some more resistor stuffing (since I foolishly forgot to order two of each of the balance/offset pots). So, could I put a 3pin switch over the global/local jumper pads? Also, I assume mixing local on one set and global on another would be bad news right?
schematic
http://gilmore.chem.northwestern.edu/kgsshvproductiondual.pdf
you definitely want global on both, or local on both.
and the output dc will drift a bit.
i would use the jumper block you typically find on pc motherboards.
.1 inch spacing. There should be miniature switches for pc mount that
would also work. (remembering that the pointer works in the other direction)
make sure they can handle 500 volts.
In case anyone was wanting to build one of these bad boys, i have since moved and now have room for speakers so i dont have any reason to build it anymore. I have the majority of the parts needed, no case or transformer, and i didnt get some of the power supply caps yet. But i did get all of the hard to find sand ahead of time. Just trying to get some of my money back on the purchases
http://www.head-fi.org/t/652453/kgsshv-parts-most-of-the-parts-needed-to-build-including-boards-no-case-or-transformer
Like Jwzhan, I just received my board and noticing some things different from the BOM I followed. I do notice more things that are different on the onboard version, though.
https://www.dropbox.com/s/xh5hy0ai28mccfo/Ampboard.jpg <Can't seem to get the other link to work>
Can I check if the extra parts are needed for the top and bottom of the board? I couldn't find any discussion on op amps and servos so I hope I'm not asking something that's already been discussed. Can I also ask what they are for?
Looking for suggestions for jumpers. They seem rather far apart for the PC motherboard type?
Best
Looks to me like, the new additions are feedback and a servo. Additional parts should be for both these items. You should be able to get the parts from Mouser.
I believe the jumper is to give you the option to use the servo or not.
You can choose either local or global feedback. The terminators give you the opportunity to try out both.
Edited by Victor Chew
Hi Victor,
I got that part, but I guess my question was would it run if I just jumpered it for global? Just realized I didn't order enough spares for the 100k resistors so ordering the additional parts from mouser isn't the worst thing, I suppose. I'm assuming this op amp 595-OPA227U will work?
Edit: Nevermind. Figured out "servo" = jumper :P
Hmm, I don't see that servo section on my amp boards. I assume it's because of the limited space on the offboard amp boards though. Which of the jumper spots are necessary to fill in if I intend on using the 1968 CCS? Also I need a wire from that single point above the 5pF cap to the 20k resistor right? The 175k resistors below the t-block are a bit in the way, but it shouldn't be too much of a problem.
Anyway, I've done all I can at the moment until I get more parts or the replacement PSU boards in.
not really getting what you are saying about the cap and 20K, but I don't believe any wires are needed. The small pads above the caps are through plated so the top and bottom layers of traces can connect, and it should serve no other purposes.
CCS choice has nothing to do with Global or Local feedback, so nothing needs to be changed. Just jump G or L (which ever you desire) to the center pad. Or use quick connect method, so you can switch between G and L if you so desire.
Just wondering.. what benefit does the servo provide in this case?
I'm sure off-board with servo is coming some time, because there are still plenty of unused space on the PCB to cram in additional circuit! :laugh:
As far as I am aware, it responds to dc voltage errors and corrects them when the signal is inputted. Its a more accurate way of correcting the dc offset than shorting to ground, which is an unatural way, and not in use this way during normal use.
Technically speaking, with the dc at zero all the time, it should therefore, make the sound better.
You still callibrate so that the servo works less hard. To calibrate I believe, you will need to remove the opa27, then power up and get both the dc offset and balance near to zero. After that, power off and put the opa27 back in.
I am not sure if the servo will be able to correct a dc offset that is way off.
