Coffee Drinkers?
4 hours ago, robm321 said:
I was interested in the clever because I can't get my French press to work without some sludge at the bottom. The clever is immersion also, so I figure it'll maintain some of the oil unlike my pour over. I may pick one up after your impressions, thanks.
Not for nothing but usually the solution is a better grind.  For starters, I'd give a slightly coarser grind a shot, assuming you're grinding your own.  Next step would be to pour through a fine mesh filter or strainer.  I still end up with just a bit of sludge in the bottom of my French-press produced coffee but I don't find it bothersome.
  • Thanks 1
Link to post
  • Replies 430
Popular Posts
This could be trouble. First results were very promising, if not entirely drinkable.  I'll toy with grind just a big more to get a full extraction but tomorrow morning should be fun and int
The Niche Zero arrived last week and I've gotten to use it.  So did the Chemex.  I chose the 6 cup which worked out well for my situation.  I'm the only coffee drinker in the house, but if I have a gu
OK - I threatened some time ago to show my signature penis latte art. Here we go:
On 3/6/2021 at 8:58 PM, robm321 said:
I have tried a courser grind (I grind my own), but I hadn't thought about pouring through a fine mesh filter. I'll give that a shot.
Yeah, some sludge is virtually unavoidable on a french press. If you're interested in something in-between that and a paper filter (where the oils and resulting body do get reduced) I've heard good things about cloth filters. I found out about this through James Hoffman's channel; here's a link -- https://www.youtube.com/watch?v=dr_I3ZVKKb4
OTOH you could consider experimenting with sifters, but cloth filters will be more worth it IMO.
  • Thanks 1
Link to post
I do pretty well drinking about 75% of the cup then dumping the rest as the sludge gets noticeable. I think I'll stick with the french press from time to time. Somehow, knowing that everyone else has the same issue makes it more tolerable.
Link to post
