digital attenuator
kevin gilmore
I used the IRC thin film with .1% tolerance.
Here's the actual values and part numbers.
RP7 15 PFC-W1206R-03-15R0-B
RP6 619 PFC-W1206LF-03-6190-B
RP5 4530 PFC-W1206LF-03-4531-B
RP4 15800 PFC-W1206LF-03-1582-B
RP3 41200 PFC-W1206LF-03-4222-B
RP2 93100 PFC-W1206LF-03-9312-B
RP1 196000 PFC-W1206LF-03-2003-B
RP0 402000 PFC-W1206LF-03-4023-B
RS0 1330 PFC-W1206LF-03-1331-B
RS1 2610 PFC-W1206LF-03-2611-B
RS2 4910 PFC-W1206LF-03-4991-B
RS3 8870 PFC-W1206LF-03-8661-B
RS4 14300 PFC-W1206LF-03-1372-B
RS5 20000 PFC-W1206LF-03-2002-B
RS6 23200 PFC-W1206LF-03-2322-B
RS7 23700 PFC-W1206LF-03-2372-B
RT 24300 PFC-W1206LF-03-2432-B
I can do the extra boards. I could also do extra assemblies, but I don't have extra relays only.
Ok, I'll take 2 extra boards only then. These will go to storage in case I have some use in the future. Please let me know how much for the extra 2 boards. Is the shipping cost of the 2 assembled boards enough to include these?
Great news...
I've completed testing on the board. I checked both relay by relay switching and did a listening test using a rotary encoder. Everything was just fine :prettyprincess:
The rest of the boards were put in for manufacturing and once they are back, we can start the assembly process as well.
I'll keep everyone posted as we go.
I'm using an Arduino Uno board. I'm taking the 5V power straight off of the USB port. The board has an on board 3.3V regulator as well as a 3.3V output.
I supplied the 12V directly to the board making sure that I tied the digital grounds together (not the analog ground).
Here's a quick picture of my down and dirty setup.
Edited by Kerry
  • 4 weeks later...
Wow... That's a lot of boards :D
Initial visual inspection looks pretty good.
I'm going to say a prayer that they all work. I've got some extra parts if not.
I'll have a chance to test some later this evening. I'll post some results as well.
