some questions on the original "dynalo" PSU as mentioned in headwize
On 10/1/2022 at 5:32 PM, luvdunhill said:
See Output section within the Electrical Characteristics in the OPA548 datasheet.
can you point out the specific/relevant section?
In Figure 13, it tells me the difference between Vsupply and Vout for a specific current output. And if wanting 2amps in Vout, the difference is only 3V. 24-16.4 is around 7volts. seems excessive considering I could've gotten better "efficiency" with a lesser Vsupply.
maybe it has something to do with the fact that the voltage coming out of the recitfiers is so high. 48VDC all the down to 16.4V is a lot of wasted energy that needs to be dissipated.
