Hongshu EH-1 electrostatic headphones and EHA-1 amplifier
Hello head-cases! New here, new to electrostats. I searched, but found very little info on the Hongshu EH-1 electrostatic headphones. (There seems to be even less info elsewhere.) There is a brief positive mention by Spritzer here, and two pictures of the EHA-1 PCB posted by MLA here, followed by Professor Gilmore's deduction of a schematic immediately after in that same thread.
Did I overlook a thread, or posts? I would love to see a review or comparison, or some measurements, both for the headphones, and for the amplifier. Kevin Gilmore's comments on the EHA-1 amp do not sound overly positive, so I have also a few more specific questions regarding a step-up transformer adapter: I read here or elsewhere that the Lundahl LL1630pp transformers, used in reverse, are a) a bit low in gain (14.4 with both primaries -as secondaries- in series), and b) a bit anemic in their low frequency power handling. I usually listen at quite moderate levels, 70 to 75dB SPL or so, so I'm wondering whether the LL1630pp's would be just fine for my purposes, given that the EH-1 supposedly makes 100dB SPL out of 100V RMS signal, and the LL1630pp should still put out well over 100V at anything above 10Hz. (For the LL1130 properties I'm referring to Aokman's posts on head-fi, in particular the plot just below, and his Youtube videos as user whatcouldgowrong.)
Aokman's LL1630 frequency response plot:
Or would something like the LL9202 (again the push pull version, with minimal air gap) be a lot more suitable (higher step up ratio and larger core volume)? I'm under the impression, perhaps mistaken, that the LL1630 might actually be easier to handle for my low power class A amplifiers (TU-8900, Zenductor 2 and the like; my only 'regular' amp is a class D Loxjie A30).
Add-on question: would there be anything wrong with using the bias from the EHA-1 when feeding the headphones through the step-up transformers, i.e. making an adapter cable that combines the EHA-1 bias and the LL1630 left and right stator connections?
Sorry if this is getting a bit long for a first post, but this forum seems like a good location to ask about electrostats.
