February 10, 200818 yr comment_94596 Ok, I'm currently looking at the Audioengine A5s since they're like a combo amp. I don't have a good place to put these speakers so I think I should start small, and get speaker/integrated amps etc after I'm done with these. The main problem is my room(s) don't have a good place for the speakers but that should be fine for now. Reks reccomended the A5s I think so I looked into it. Any ideas? Like should I go for it? or anything else you guys reccomend? I'm trying to stay away from hi-fi speaker systems atm. so anything combo should be good. Budget is maybe.. $300-600, really depends what it is that I'm getting. I need to patch up my headphone rig first anyways.. Report
February 10, 200818 yr comment_94600 Go active. There's also about a Brazillian questions you should be asked -- and you should be asking yourself -- such as, nearfield/midfield/farafield/outfield? Sweetspot listening? Close to wall, or pulled out in the rooom? What are you looking for (soundstage, prat, etc.)? What will you be listening to, on it? Report
February 10, 200818 yr Author comment_94603 i have guitar lessons so i gtg, but .. ill type something quick I was gonna use it like in my room but I'm using the laptop in a corner, but I think I should wait it out. I might get a HDTV in the family room.. it should be ok with speakers, since its centered on the wall, but thats about it.. Report
February 10, 200818 yr Author comment_94635 Anything more "value" worth at the $500-600 range? Report
February 10, 200818 yr comment_94649 Wharfdale Diamonds are also supposed to be pretty good, but again, what are you looking for? You want bass? Just get a subwoofer. No speakers, just a subwoofer. But you know, if you're Good To Go, then w/e ... brbq ... Report
February 10, 200818 yr comment_94697 But you know, if you're Good To Go, then w/e ... brbq ... Report
