luvdunhill Posted August 26, 2008 Report Share Posted August 26, 2008 so, I've been playing around with some diodes on a power supply and found some I like, but I think I'm cutting it too close with the current rating. The transformer is 82VCT 50VA R-core and I have a 300mA fuse on each rail after the main supply capacitance, which is around 3000uF per rail. I wouldn't expect any more than 300mA per rail, hence the fuse choice. That being said, there is in-rush and the like to consider, and blowing a bridge isn't too exciting in my book. So, without admitting how stupid I was, and how low I went... in your opinion, what's a good rule of thumb? Quote Link to comment Share on other sites More sharing options...
cetoole Posted August 27, 2008 Report Share Posted August 27, 2008 so, I've been playing around with some diodes on a power supply and found some I like, but I think I'm cutting it too close with the current rating. The transformer is 82VCT 50VA R-core and I have a 300mA fuse on each rail after the main supply capacitance, which is around 3000uF per rail. I wouldn't expect any more than 300mA per rail, hence the fuse choice. That being said, there is in-rush and the like to consider, and blowing a bridge isn't too exciting in my book. So, without admitting how stupid I was, and how low I went... in your opinion, what's a good rule of thumb? Well, you dont provide all the needed information, so some assumptions must be made. I assume your rectifier is a FWB, though you did specify that you are using a 82VCT transformer. Also important, and my assumption is yes, but are you using a pure cap input filter? Finally, what is the DCR of your transformer? I would tend to guess maybe 10ohm or so, but it makes a pretty big difference. You can use PSUDII to get a pretty good picture of what is going on with your power supply. Rule of thumb though, I would stick with 2A rated diodes or higher, though I have used 1A rated diodes for extended periods of time with no ill consequences. That said, I can be a glutton for punishment. Quote Link to comment Share on other sites More sharing options...
