Prosink?
I don't think it will. might be interesting to find out, but I have enough cheap
meters, don't need another one.
if you have 50 feet or more of cable you want to test you can drive it
with a square wave 20khz or more, put a scope at the other end, put
a pot at that end, and adjust for best looking wave. Then measure
the value of the pot
  • Replies 52
  • Views 37.2k
  • It's really easy to implement on your own. You just need any cable that is 75 ohms and pretty consistent impedance across the whole cable, and each end of the cable is terminated with a 75 ohm resisto
I don't have an oscilloscope.  :-[
Thank you for pointing out that approach.
This video may be useful:
  • 1 year later...
Is there a market for this style cable?  I bought a set of prosinked cables from eric343 years ago, and would love to revive them if they're as fantastic as Dr. Gilmore says.  Thoughts?
