April 17, 200719 yr comment_29375 Are there any tube socket adapters worth getting for a PPX3 Slam with native 6sn7? I've got the itch to roll. Report
April 17, 200719 yr comment_29379 Are there any tube socket adapters worth getting for a PPX3 Slam with native 6sn7? I've got the itch to roll. Lots .... ECC TYPE #1 = 5965/ 6414/ 6829/ 7062/ 12AT7/ 12AU7/ 12AV7 .... Possibly more if you have a texture control. ECC TYPE #2 = 6BC8/ 6DJ8/ 6922/ 6CG7/ 12BH7 7N7 adapter = 7AF7/ 7N7 Report
April 17, 200719 yr comment_29380 Lots .... ECC TYPE #1 = 5965/ 6414/ 6829/ 7062/ 12AT7/ 12AU7/ 12AV7 .... Possibly more if you have a texture control. ECC TYPE #2 = 6BC8/ 6DJ8/ 6922/ 6CG7/ 12BH7 7N7 adapter = 7AF7/ 7N7 Wait... does the 6922 and the 6cg7 have the same pin out? Isn't the 6cg7/6gu7/6fq7 it's own adapter? Report
April 17, 200719 yr Author comment_29383 Lots .... ECC TYPE #1 = 5965/ 6414/ 6829/ 7062/ 12AT7/ 12AU7/ 12AV7 .... Possibly more if you have a texture control. ECC TYPE #2 = 6BC8/ 6DJ8/ 6922/ 6CG7/ 12BH7 7N7 adapter = 7AF7/ 7N7 Yup, I have texture control. You mean I'll actually be able to use texture control for something? Report
April 17, 200719 yr comment_29384 Well... If you use the 12ax7 which has a amplification factor of 100 or the 5751 which is a gain of 70 vs a 12au7 at about 20, you might want to use your texture control in order to get some use of your volume control Report
November 13, 200718 yr comment_64311 If you feel like waiting a year... PM me I'm selling my ECC#1. Report
November 13, 200718 yr comment_64313 PM me I'm selling my ECC#1. You realize you're digging up 7 months old thread, right? Oh, and he doesn't have his SP amp anymore. Report
November 13, 200718 yr comment_64360 Seriously, the board even gives you a warning when you try to post in a inactive thread. It'll tell you that you're digging up some ancient thread, and then ask if you still want to post in it. Report
