postjack Posted June 30, 2007 Report Share Posted June 30, 2007 Just because my turntable only has one headphone out, this prevents me from having to pull cables every time I want to listen to a different amp. Does a preamp actually do anything to a signal, or is it just a fancy switchbox? This has always confused me. Quote Link to comment Share on other sites More sharing options...
hungrych Posted June 30, 2007 Report Share Posted June 30, 2007 A preamp does amplify the signal. I'm pretty sure the melos has a tape out, which doesn't do anything to the signal. So use that. Quote Link to comment Share on other sites More sharing options...
postjack Posted July 1, 2007 Author Report Share Posted July 1, 2007 A preamp does amplify the signal. I'm pretty sure the melos has a tape out, which doesn't do anything to the signal. So use that. cool, thanks. Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted July 1, 2007 Report Share Posted July 1, 2007 the line outputs certainly go thru the tube and a pair of fet outputs so there will be a definite sound to those outputs. It is unclear from the schematic where the tape outputs are wired to http://gilmore.chem.northwestern.edu/melos.jpg Quote Link to comment Share on other sites More sharing options...
postjack Posted July 2, 2007 Author Report Share Posted July 2, 2007 Just for fun, I ran ICs from the preamp out to the dynahi, then the tape out to the dynahi. The line out definitely sounded different, and was run through the Melos volume pot, i.e. I could still control the volume from the Melos. With the tape out, the volume pot on the Melos does nothing, and the sound is unaltered. Looks like the tape out solved my wiring problem, thanks to hungrych and kg for the help. Quote Link to comment Share on other sites More sharing options...
