December 31, 200718 yr Still enjoying my Hd580 wired for direct balanced out from XLR out of my miniDAC, find it useful to move around from room to room in the house. Couple of questions: 1. You always see threads about HD580/600/650 used in this manner to good effect - just curious, any other headphones that respond well to running direct XLR out of these type of DACs? 2. Typical full-size HP's terminate in 1/4" plugs - are there such extenders that are female 1/4" (to plug the normal headphone into) to 2 x 3 pin XLR (to connect direct to DAC)? 3. Would like to try balanced on my k271s. It has detachable mini XLR at headphone end. Possible to replace this with balanced cables that go to 2 x 3 pin XLR? No intention to harm the stock cables on my L3000/W5000/K1000, but I thought it may be fun to fiddle with my HD650/K271s (HD580 was acquired with balanced cable hardwired.
December 31, 200718 yr 3. Would like to try balanced on my k271s. It has detachable mini XLR at headphone end. Possible to replace this with balanced cables that go to 2 x 3 pin XLR?I don't think so, since it is just one mini XLR, I think you need to completely recable them dual entry.
December 31, 200718 yr I don't think so, since it is just one mini XLR, I think you need to completely recable them dual entry. 100% correct. If you need someone to do the work, I can do it leaving it single entry, but you'd likely lose the detachable cable solution. Let me do some thinking while looking at my 240s.
December 31, 200718 yr 100% correct. If you need someone to do the work, I can do it leaving it single entry, but you'd likely lose the detachable cable solution. Let me do some thinking while looking at my 240s. I have an elegant solution. If interested, let me know.
January 1, 200818 yr Author I have two K271S, as I needed closed solution at various locations, however, one's just been lying around collecting dust. If you could pull it off, that would be awesome, miniDAC XLR out to balanced K271S -- a real compact, transportable and rugged system -- maybe get a camera type case to lug it around location to location. Not sure how it would sound, but I'm willing to sacrifice one of the pups. Hardwiring and drilling holes would be OK. will PM you. btw happy new year everybody
January 1, 200818 yr If you could pull it off, that would be awesome, miniDAC XLR out to balanced K271S -- a real compact, transportable and rugged system -- maybe get a camera type case to lug it around location to location. http://www.apogeedigital.com/products/minidac.php?show=accessories http://www.headphone.com/products/system-bags/headroom-complete-headcase---black.php And remember, you can run your Mini-DAC off of an external battery pack.
January 1, 200818 yr my balanced Proline 750's do not sound good from my minidac's xlr out's, they sound, just ok from its 1/4" but sound better from my little technics speaker amp. My modded K340's sound quite fun from my minidac's 1/4"
