December 25, 200817 yr I have a bunch of flac files I want to convert to alac. I dl Max and it will transcode to aiff. It is asking me to choose linear pcm 8, 16, 24, 32 bit big endian integer. What should I choose?
December 25, 200817 yr Mike most likely that is word length if you want them to be iPhone compatible then go 16. I think I have used switch in the past for this but I do not recall it asking that.
December 25, 200817 yr Mike, if you're trying to convert it to ALAC on Max, add one of the MPEG4 Audio (it's the first one, IIRC) option under "Formats" in the preferences and it will give you a choice for ALAC.
December 25, 200817 yr Author Mike, if you're trying to convert it to ALAC on Max, add one of the MPEG4 Audio (it's the first one, IIRC) option under "Formats" in the preferences and it will give you a choice for ALAC. That was my goal but I wasn't sure if the MPEG4 Audio was ALAC. I will give that a try on the next one. Thanks
