Apple Express Audio Out Through USB?
how good are you at firmware programming?
I'm the BEST.
No, of course not. I have no idea about any of that stuff. I was thinking more along the lines of using some jumpers and all would be good. ;)
So not an easy project in other words, eh?
The real way to do it is to crack open the express, and replace the audio daughterboard :)
Yes, this has a decent shot of working, cutting the existing traces to the USB jack, removing the audio board, and wiring the usb pins which had been feeding the audio board to the USB jack, in a manner which doesnt completely screw with the USB wiring standards. We know that at least older versions used the PCM2705 for the audio board, so it would be fairly simple on these, but I have heard, though unsupported by photos or anything, that the current expresses use something else. Also, since the thing is sonically welded together, you would have to recase it afterwards, instead of just closing it back up. Well, maybe duct tape would work.
