headwize
headwize and my other sites will be down starting
november 26 thru the 28th or 29th due to power
shutdown to wire in the power to my new building.
Also down december 29 thru january 1 to finish
the job.
KG, any idea if headwize will ever be active again? thx..dB
I don't see the forum part of it ever being active again due to serious
security holes in the implementation of the database and php. Mostly
the php.
I've offered to migrate the headwize library over here, but Chu Moy wanted all the posts moved as well, which would be way more difficult and not nearly important IMHO as the library is. At least that was the case that last I heard from Chu which was, probably a year ago now? My offer still stands for migrating the library over here, I'd be willing to do the work to get all the projects moved over into the CMS of vBulletin 4.
Would there be a way to export the data to, I dunno, DVD? I'd happily pay for a set. Lots of good discussions there in the past. I can understand why Chu wanted the discussions along with the library.
With chu's permission i could do just about anything. Including all the library as html instead of php.
