October 7, 200719 yr Author comment_55567 Let me know if you're having trouble Dan, my cable supplies order came in Friday so I've got enough stuff to make a quickie that would help you raise some more funds. The most important questions is: how's your amp doing? It sounds great. There may be a relay issue, it's taking forever for the muting circuit to shut off on powerup, but I didn't spend a lot of time at the meet worrying about that. I'll check it out when I get the amp set back up in a few days. Report
October 7, 200719 yr comment_55570 It sounds great. There may be a relay issue, it's taking forever for the muting circuit to shut off on powerup, but I didn't spend a lot of time at the meet worrying about that. I'll check it out when I get the amp set back up in a few days. IIRC the delay is variable based on what headphones you have plugged in (their impedance plays a role) so you may find that it's longer or shorter depending on what you're using. As long as it's eventually closing and staying closed it's probably working just fine. Report
