October 3, 20223 yr comment_894720 so due to a comment i made over there, someone wanted to know if i had the eddie current dht filament schematic. here it is. eddiecurrentfilament.PDF Edited October 3, 20223 yr by kevin gilmore Report
November 5, 20223 yr comment_897144 My ignorance but I'm curious what's the purpose of C14, C15 and R11 at the output of the power amp in this configuration? Report
November 6, 20223 yr Author comment_897180 keeps any dc out of the transformers. even small amounts of dc would saturate the transformers real quick. mikhail used the same circuit on the square wave instead of using a servo. Report
January 27, 20242 yr comment_927610 Thanks Dr. Gilmore, Got a pbc made from the schematic. Played around with R1=120-ohm to get a good-enough sinusoidal wave; adjusting R2 and R3 to 10K to get 76kHz wave. Hand-wounded trafo, not pretty but does the job... Report
