well, other than height :) Actually, I'll be using a 2" dome mid and have been using that as listening height for the crossover calculations.
I guess I meant things like, how large should the top plate be in proportion to the speaker, construction, "features", etc.
Since you mentioned it though, what's a good "average ear height"? I think there was some number in a Vandersteen setup guide I used to have, but I no longer have it. I was assuming 38"-42".. 2" dome mid is 8.5" up the baffle, so 25" Dynaudio Stand1 probably is too low ...
When did oatmeal become FOTM?
Somewhere around 2/14
These are not rules of thumb, these are MHO's:
plate == base of speaker -- I don't like overhang, because it seems less stable, but neither do I like the plate to be bigger -- the speaker baffle should not have any additional reflecting surfaces right there.
Construction == should be stable, inert, etc. (seems rather intuitive, not sure what you're looking for here). Shouldn't ring -- basically, same rules as would apply to the speaker cabinet.
I like three legs (as opposed to one, two, or four, etc.).
Most of the magazine writers swear by sand-fillable. I don't, but that's me.
just wanted to bump this thread, as I'm getting closer to finalizing the design for a pair of speakers. I've had great luck with placing the listening axis at the midrange driver. Of course there is no way to know what the speaker designer intended, but I would wager that this would be an interesting experiment for those with commercial stand mounted speakers.
Here's the FR of the midrange driver I am using:
[img width=150 height=91 alt=morel-mdm]http://www.head-case.org/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=1999&g2_serialNumber=2&g2_GALLERYSID=ea03dac2fefb42c134d55fcca2b988df
Guest sacd lover
The usual method is for the axis of the tweeter to be at SEATED ear height = 36"-38" from the floor.
...this would be an interesting experiment for those with commercial stand mounted speakers...
...with a midrange. Alas, most of mine are two-ways, otherwise I'd take you up on that experiment.
Dali's, for one, or not intended to be listened to on-axis, they are intended to be pointed straight ahead, and listened to off-axis slightly. I think it's manufacturer-specific.
agreed. It just seems that since tweeters have relatively good off-axis response, and the upper end of the midranges have some break-up, that it makes sense to establish the listening axis with the midrange, especially when using shallow slopes, like I will be (first-order).
