November 13, 20232 yr comment_923745 I have the L700 MkII and I find the headband pressure too high. I wonder if the original L700 headband would lessen the pressure as the “arm” of the forks are a straight construction without the bend at the bottom in the MkII model. Any “swithers” between the too models heamdband ? Report
November 13, 20232 yr comment_923747 I've put Mk2 forks on a Mk1 but the pressure has never bothered me. You can bend the arc a bit on these but don't take it too far. Report
November 13, 20232 yr Author comment_923766 Thanks The arc looks like plastic - perhaps warming up with a hair dryer before bending. Report
November 14, 20232 yr comment_923783 7 hours ago, spritzer said: It is plastic covering a metal core Does 009 have the same metal core in plastic? Report
November 14, 20232 yr comment_923785 Yes, they have an identical headband it's not as strong as the 007 arcs which can be bent back and forth. Report
November 20, 20232 yr Author comment_924074 Thanks Spritzer - i did it very carefully and the fit is now perfect.. Report
