finally an electrostatic transportable
On 11/16/2025 at 3:30 PM, kevin gilmore said:
Hi Kevin.
Thanks for your reply.
The boards are sandwiched together with a thermally conductive material and a bunch of thermal paste between the housings.
I couldn't figure out an easy way to get inside without breaking everything.
I'm hoping the problem is still in the power supply, since you're right—it was heating up.
The diodes were burning out frequently, then the transistor itself, and then possibly the transformer itself—its resistance is now 0.1 ohms on the primary winding and 4 ohms on both secondaries. I'm not sure if that's normal.
It's been working without any problems on a third-party power supply for half an hour now. I'll continue testing.
I couldn't think of anything simpler or better than connecting 4 of these modules to get +-400v
To my surprise, these modules produce even more than 10mA and +-400v
But they have one major drawback: noise. The throttles in them make noise.
Edited by Omega_ELS
  • Replies 87
  • Views 21.1k
  • kevin gilmore
    kevin gilmore
    someone asked for this, so here is the amp board.  working on power supply board now need to find a suitable chassis. power supply board in progress. cfaelectrostatschem2-4 - CADCAM.ZIP
  • kevin gilmore
    kevin gilmore
    pretty close to production now.
  • kevin gilmore
    kevin gilmore
    there is an american manufacturer of the same power supplies, same foot print. about double the price. don't remember where. i have too many new toys to play with at the moment.  one makes 116db
links for those power modules please.
how warm does the chassis heatsink get?
edit: what is the total power input that runs the switchers?
Edited by kevin gilmore
https://www.ebay.com/itm/275736642694
its max MAX1771 12v to 150-220v DC
it can be ajusted
i set 200v and just connected it 200+200 for +400 and 200+200 for -400
I read a similar problem about noise here but I couldn't find a solution.
Well, unfortunately, I don't have a thermometer or pyrometer, but it feels like it's probably about 45 degrees Celsius or so - maybe more/less, It dissipates pretty well.
Edited by Omega_ELS
those are not isolated. at least they sure look non isolated. how you put them in series with common power supply input.
i use 4 of this one
https://www.lcsc.com/product-detail/C5279972.html
DEXU Electronics B1212LS-1WR3
it's something like galvanic isolation
Edited by Omega_ELS
It's been working reliably for an about hour now.I will continue testing 24\7.
The power consumption of the modules themselves from the 12V power supply is 550 mA under load.
The power consumption of the amplifier itself from these modules at +-400 V is only 5.5 mA.
the dexu parts are providing the isolation. this works. extra parts, maybe the same performance.
On 11/16/2025 at 6:42 PM, kevin gilmore said:
the lcsc parts are definitely isolated.  they work fine.
the maxim boards are not isolated and you cannot put them in series because input ground and output ground are tied together.
Yes, you're right.
That's why I had to connect it like this.
I'll get this thing tomorrow
12v to +-390v DC DC
I hope it doesn't beep
or at least there's a way to eliminate the beeping with an RC filter or something.
I'm just trying to try all the DC-DC modules before spending $50+ on those cool USA12400S-8 ones. But most likely, I'll just have to buy them.
Edited by Omega_ELS
those modules do work, i have a few. the diodes on the back run stupid hot. never tested for hours and hours. there was a company in poland i think building an electrostatic amp with 4 of these. first version with no fans. second version with fans. both versions burn up in a couple of months.
so my version has an amplifier power of around 20 watts.  the hvrv version seems to be half of that. may be the reason why there were a couple of comments about the sound vs the original to126 version.
Well, if I turn the volume up to maximum, the amplifier can consume up to 10 mA at peaks, but I don’t listen that loud. I dont know if its minited to +-400v or maybe it can handle more.
Edited by Omega_ELS
12v to +-390v DC DC
So I connected this yellow DC-DC.
It can produce -400 and +380 volts from 12 volts.
Which is 20 volts less than I need.
Interestingly, it can produce -400 volts in one side.
And only +380 volts in the other. Funny.
Now I'll be looking for ways to squeeze another 20 volts out of it.
Or should I just skip the hassle and buy some decent USA S400 modules and be done with it.....
Edited by Omega_ELS
Perhaps Better to get down go 380 the other one, no?
that is a dual voltage output, single ended flyback supply.  can't change the positive voltage without changing the negative.
so you really need 2 x single output units. and then you might be stuck with +/-380.  which should work.
Hi Kevin
Well, it still works.
It's just that the voltage distribution isn't ideal for -400V and +400V.
I'm not sure if it's possible to supply different voltages.
The sound is good and quite clear.
But I think I'll still have to buy those proper modules and settle the power supply issue—there's no way to get +-400V 6mA for under $50.
So, I've been testing it for two days.
It's thermally stable for 12 hours.
I think the tests can be completed.
I just don't know what the upper power limit is.
I tried +-400V and it works.
And even at +-450V.
I wonder if it can withstand +-500V or 600-700-800V?
I saw someone build it with four 400V modules.
So, +-800V.
assuming the parts are stn9360 and matching npn are 600v parts the front end limits to +/-600v. with cascodes you can get to +/-900.   anything over +/-600v will damage the headphones.
On 10/27/2025 at 8:43 PM, spritzer said:
CRCW's should be just fine so something else might be drifting there.
Does your board have a ground plane?
I always have a ground plane or rather two, on both sides.
So, friends, anyone built this portable with success ?
Mine works without any problems.
I tested it for 12 hours straight.
Yes, it's quite hot.
But all the heat is dissipated by the case.
Power supply: +-400V.
5mA current consumption.
12V input.
1-2A power supply required.
I'd say the sound is on par with KGSS, definitely not worse.
12V input.
Just built as per schematic, and worked straight at first attempt?
no, omega-els has the hvrv-hansen portable. and the power supply blew up.  so he is using outboard dc/dc converters to power the no longer really portable thing.
Well, let's be honest, it was never portable. It consumes 600ma + more like 800+ for DC converters. No small battery can handle that—for example, 10 hours. Yes,we can use a power bank, but that won't be very portable.
Edited by Omega_ELS
at the moment, do what i did 30 years ago.   srm212 plus 12v 7ah gel cell. its portable. kinda portable.
or buy 4 x apex opamps and run them class C with the dc to dc converters.
i wish i had a better solution. getting all those transistors to touch the heatsink at the same time is not easy.
even the koss box requires a decent size battery.  (6 x D cell)
