June 14, 200917 yr A quick search online hasn't yielded any helpful results.. I picked up a refurb T40 a while back. The last few days I've had issues where the video would cut out completely, or the display would get distorted, looking as if there were a bunch of the same images just barely offset. It always happens when handling the laptop or when typing. It can be manipulated by applying pressure on the case. Sometimes a bit of pressure tweaking the case can make it come back completely, or at least get it to the point where I can save what I'm doing. I'm guessing it's the display adapater, which AFAIK is integrated and non-servicable. But I thought it was worth seeing if there was anything else I should look into first before toying with a tear-down looking for loose connections. Thanks in advance.
June 14, 200917 yr Author How can I have spent the last hour looking for stuff, and you have something posted within minutes? Thanks, Nate. I'll print the .pdf manual at work tomorrow.
June 14, 200917 yr Yeah, it's a known issue. The fix: forum.thinkpads.com • View topic - GUIDE: Reflow GPU fix - 56K WARNING!!!
