July 11, 200917 yr comment_254284 I've been doing some Google searching and also on diyaudio but I can't seem to find a nice answer to which pins are connected to what on Quad 5-pin and 4-pin DIN interconnects. Anyone here know? -think ive got it now- Edited July 11, 200917 yr by Duggeh Report
July 12, 200917 yr comment_254448 I found [ame=http://es.wikipedia.org/wiki/Conector_DIN]this[/ame] on the Spanish Wiki for the 5 pins DIN, which meets my previous experience with those connectors. Many moons ago I also had a microphone using a 3 pins connector into a recording machine. I'll translate the numbers assignation: 3 Left channel "out" (I suppose it means -) / Mono 5 Right channel "out" (stereo use only) 2 Ground 4 Right channel "in" (I suppose it means +) (just used in stereo) 1 Left channel "in" / Mono My wild guess is that the 4 pins connection in stereo just skips the ground pole. I didn't found information about it. I suppose that Quad sticks to the normal DIN configuration. Maybe contacting them to confirm the point is your best bet. Good luck. Report
July 15, 200917 yr comment_255835 Haven't used din in years. Not since my last piece of Naim gear. Report
