Duggeh Posted July 11, 2009 Report Share Posted July 11, 2009 (edited) I've been doing some Google searching and also on diyaudio but I can't seem to find a nice answer to which pins are connected to what on Quad 5-pin and 4-pin DIN interconnects. Anyone here know? -think ive got it now- Edited July 11, 2009 by Duggeh Quote Link to comment Share on other sites More sharing options...
Torpedo Posted July 12, 2009 Report Share Posted July 12, 2009 I found [ame=http://es.wikipedia.org/wiki/Conector_DIN]this[/ame] on the Spanish Wiki for the 5 pins DIN, which meets my previous experience with those connectors. Many moons ago I also had a microphone using a 3 pins connector into a recording machine. I'll translate the numbers assignation: 3 Left channel "out" (I suppose it means -) / Mono 5 Right channel "out" (stereo use only) 2 Ground 4 Right channel "in" (I suppose it means +) (just used in stereo) 1 Left channel "in" / Mono My wild guess is that the 4 pins connection in stereo just skips the ground pole. I didn't found information about it. I suppose that Quad sticks to the normal DIN configuration. Maybe contacting them to confirm the point is your best bet. Good luck. Quote Link to comment Share on other sites More sharing options...
Smeggy Posted July 15, 2009 Report Share Posted July 15, 2009 Haven't used din in years. Not since my last piece of Naim gear. Quote Link to comment Share on other sites More sharing options...
