good amp for vinyl with a good heaphone out as well maybe tubes?
hi, any good recommendations for a good amp or tube amp with sub outs and hopefully a good headphone output as well?
good synergy with vinyl?
thanks
yes.
I find that Phono stages typically have the best synergy with vinyl. Once when I was but a young fool I attempted to run my Stax O2/717 directly off of a MM cartridge. OOH the horror. Fist it took all the volume knob to eek out any sound! Secondly, the highs were a good 20db higher than the mids, and the lows a good 20 db lower! can you immagine? Tilted up? Indeed.
Heresy, don't you know that less stuff=better sound?
I want to find a tube amp that isn't an amp. I think that'd be ideal.
Ask and you shal receive.
adsc_0002.jpg?t=1270950183
adsc_0006.jpg?t=1270950145
The Least-Espressivo.
It isnt an amp, It dosnt have tubes or transistors, and it runs headphones well. 2 out of 3 ain't bad.
Man, I bow to your techy knowledge. Now ima eat some chocolates...
thanks
Your two posts here have both been giant piles of fail, I suggest not trying for a 3rd if you want to remain able to read the forums.
