Cheap Raal Direct Drive Amp
If you have some transformers floating around, it would be simple enough to make a cheap linear supply to try out.  Add some beefy caps in a CRC or CLC setup...
  • Replies 55
  • Views 22.4k
  • RAALstar v0.1 with one of Ray's old test discs raalstar.mov
  • Milled a second board today and after some struggling I eventually have a stereo opamp driver.    Now I listen to this    and this… Grüner Veltliner for my father-in-law... he was
  • I like how a heatsinked 3U chassis is now the modest build answer
5 minutes ago, kevin gilmore said:
wire the headphone grounds directly to the amp boards, not the power supply
Thanks Kevin. That is what I have done.
I have balanced inputs so the signal/chassis ground is isolated from the smps and amp board grounds. In other words the smps power ground and output signal negative is floating and not tied down.
I probably need to do a bit more experiments to try and identify the issue I.e. whether it is conducted noise from the SMPS, EMI pick up, earth loop etc.
I was just wondering whether there was some standard EMI suppression filter required with SMPS?
has anyone fully built his amp up and would be willing to put together a second one for someone that is totally inept with a soldering iron and schematics, asking for a friend 🙂
