judo Posted 8 hours ago Report Posted 8 hours ago (edited) I do not remember I ever started a topic but I am here for a decade or more. I am playing with google AI for a time and I like it. I left out chatgpt so this is new for me. I liked to think I am good to search info from the internet but this thing is so much better. Specifications, go not go situations with some equipment so much easier to resolve. I was curious I asked to design a opa548 virtual ground circuit for me ( this is why diy) and I built it. Not so complicated circuit, I built it and almost worked. The problem maybe was the messy breadboard not the AI, a pin had to be grounded to stabilize the opa. I was a software developer, supporter all my time so I know this AI something like a mirror for as so it is about as stupid as us. Edited 8 hours ago by judo
Dusty Chalk Posted 8 hours ago Report Posted 8 hours ago AI is not yet at the stage where you should trust the answers given you. For example, I used an AI to translate an algorithm (Reverse Bits in Word by Lookup Table on this "Bit-Twiddling Hacks" page) to Rust, and the values in the lookup table that it came up with -- it had trouble converting the macros to values, plus it didn't use macros -- were wrong. Fortunately, I know Rust well enough to have vetted and corrected the answer, but I feel the same needs to be done for everything -- let it suggest to you, but don't copy and paste the answers, make sure you understand everything it's doing with its solution. That said, it can be a very powerful tool -- I used the entire translation (fraction of a second) and vetting process (an hour or two at the most) as a learning experience. I would recommend you do the same with your efforts. E.G. don't assume that the fault was yours, make sure you understand exactly what the fault was, and learn what it would take to fix it. Or if it was the AI's fault, learn what it would take to have caught it before building the circuit.
judo Posted 7 hours ago Author Report Posted 7 hours ago i have not think it will design the circuit this AI is a chatting machine learn from all the chats from the internet. (my keyboard is bad so there will be mistakes) I read about AI circuit design it exists. But it is f*cking good from this standpoint. I think I found its main source for the circuit but the result was not the same. I was awed but I like it because I can use it not for this day to day.
dsavitsk Posted 7 hours ago Report Posted 7 hours ago 44 minutes ago, judo said: I asked to design a ... circuit for me ... it and almost worked.
judo Posted 7 hours ago Author Report Posted 7 hours ago Funny:) I think for the existing AIs it is easiest to be funny than design a working circuit. There are a lots of funny people in the internet for source. How long?
