What to loof for in a VariAC
Personally, I wouldn't buy once unless it had 0-250VAC output
I see what you're getting at, how about this one? Just as a starting look.
Mastech 5KW VARIABLE TRANSFORMER VARIAC 5000VA 0-250V - eBay (item 380161906580 end time Oct-04-09 17:28:02 PDT)
I have a Mastech DC Power supply and they seem to make serviceable gear for the Hobbyist.
How stable is power coming from a Variac anyway? I know in our lab we use a metered one.
I use the even-cheaper variac from MPJA:
500VA 0-130VAC VARIABLE TRANSFORMER-MPJA, Inc.
It's been fine for low-power applications (DAC and headphone amp power supplies); haven't tried it for heavy-duty projects.
One thing to keep in mind is that the actual output voltage will vary depending on your local AC voltage, so the volt markings on the dial may not correspond to what the variac is really putting out. Check the built-in meter, or better yet, check with your multimeter.
EDIT: It may just be the photograph, but the Mastech you linked to seems to have the voltage knob way off-kilter. Like it was dropped on it's head ;)
